Question about Onkyo Audio Players & Recorders
Onkyo tx-sr700 broken off volume knob - Onkyo Audio Players & Recorders
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
mjjdesigns
  • 98 Answers
SOURCE: Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Posted on Mar 19, 2009
SOURCE: Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Posted on Apr 17, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
SOURCE: How can I reset my Onkyo TX-SR601? Hard reset...
Hold Video 1 and Press the power button then turn it back on i had the same problem
Posted on Mar 11, 2010
Replacement Volume Knob Onkyo TX-5811
Maybe the cheapest and the best way to get the knob is to check ebay and buy the hole receiver for parts or check the link below. :) hope it helps
https://www.partstore.com/OpenSearch/Model/Onkyo+Corporation/Onkyo.aspx
Jan 29, 2014 | Onkyo Audio Players & Recorders
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Volume is stuck on max. The pot does not seem to be the issue. I do not have a remote. Tried to connect other remotes but unable to find a code that will work. Machine is new to me. Bought it for...
Do you have the manual and have you thumbed through it?
Register and download the manual for free at
retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR700-Receivers-manual/id/365ag223/t/2/
It always puzzles me when someone fixates on the remote when a unit has front-panel controls. You say "The pot does not seem to be the issue." Does that mean it is ineffective or is it faultless in your estimation?
The HUGE volume knob (#16 on page 8) controls volume (in the main zone), too.
If your complaint involves speakers on Zone 2, the up/down arrows at #22 on page 8 apply.
Feb 26, 2011 | Onkyo TX-SR700 Receiver
My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
Oct 16, 2009 | Onkyo TX-SR700 Receiver
Onkyo tx 906 amp
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jul 02, 2017 | Onkyo HT-SR700 System
Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Sep 16, 2007 | Onkyo HT-SR700 System
151 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
