Nokia N72 Cellular Phone Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display Problem I have problem with display I.C that makes only light to show on
Anonymous
Level 2:
  • Expert 277 Answers
  • Posted on Sep 30, 2009
Anonymous
Expert
Level 2:
Answers
277
Questions
0
Helped
80696
Points
837
Try a software update or a reformat first in case you just have a software problem. If that doesn't help, you'd have to get it repaired.
Display doesn't light up nor show anything but the buttons make sound and treadmill works all of the buttons work but no display
I think you need to replace the display of your tredmill. Everything is fine with your tredmill but only it`s display need to be replaced.
How do i enhance the display light
While on-hook or receiving a call, The Navigator Key is used to adjust the display contrast*.
Hp pavilion dm4 laptop no display in built in display, but showing display in external display
It could be a bad video cable or a failed screen. You could try reseating the cable at both ends. You might try moving the screen forward and back to see if the screen flickers at all. That would confirm the cable. If the backlight went out on the screen itself, you should still be able to see the image under bright light on the screen. It just would not be back lighted. If the screen is bad, take it out, look at the make and model of the actual screen (a Dell laptop could have a Samsung screen, etc) and then look that up specifically on eBay or Amazon for the best price.
LED not working properly
Yes, I have exactly the same problem after running the de-scale routine, we've only been using the machine for 4 months (in Melbourne where the water is soft). You can dimly make out the icons on the display and the machine works Ok. The display contrast is set correctly, yet the green images are not showing up properly while the red images do show up.
My LG GW305 has a display problem, it is just showing lights on the screen, but it can make calls. Tried other screens still not displaying. thx
Showing blank(white screen) display a even it works. There is problem with your display IC chip which has been damaged you need to change it and get you software update.There is conection loose i this.
Aug 17, 2011 • Cell Phones
10helpful
How do I set the Woods N1506 timer?
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
2helpful
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
2helpful
N72 white display
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
No Display for samsang sgh a 800
my Samsung A800 also lost its inner display recently. When I open the phone, the inner display lights up but fails to show any image. Outer display is mostly OK, once it had trouble to "lock" the image and after opening and closing the phone a few times the outer display showed the image with light and dark bits inverted.
Switching phone off and on restores the inner display most of the time, but the image only lasts until I close the phone.
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
