Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven panel I was using the convection oven on my Jenn-Air duel fuel range, I hit the cancel button by mistake, Now when I try to turn the oven on all I get is beeping. None of the panel works. I can turn on the timers and the fan, but no oven features.
  • howalin Jan 29, 2008
    My oven panel is currently not working. the only buttons that will even make a sound are the Upper and Lower Cancel buttons. The clock works, but the Hold will beep and flash for Upper and Lower oven even when no one is using the oven. I have tried to unplug the Oven and that did not work. Currently have a call for service from Maytag. Could be a control panel issue.
  • Anonymous May 14, 2008
    The numbers on the control panel 4-5-6-8 and 0 don't work, so I can't set the timer or the temperature using any of these numbers. It worked fine 1 week ago, and we had a bad storm and this is the first time I have used it since then. I flipped the breaker switch, but still had the problem.
  • 146 Answers
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Posted on Dec 21, 2007
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Jenn air convection fan squeals (JGS8850BDS)
turn power off remove gill in oven remove fan blade now remove back panel and remove convection fan motor and wirers Now revere procedure to install new fan motor Cheers
May 05, 2012 | Jenn-Air JGS8850 Gas Kitchen Range
I have the Legacy model 3530-3630 gas/electric problem is this: for the past few days there is what sounds like a fan running in the oven. This runs constantly whether I am using the oven...
This is the convection fan. My hearland range does this too, after power loss in the house. I cancel it by starting and then stopping convection mode. ie. hit convection (fan icon) start (running man) and then cancel (X).
Dec 27, 2010 | Heartland 3530 Dual Fuel (Electric and...
Our jenn air model js9860aab control panel buttons on the panel do not respond--is there a rebuild kit available to repair this -- because without these buttons, the convection oven of this duel fuel range...
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Jan 28, 2010 | Jenn-Air JDS8850 Dual Fuel (Electric and...
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air auto clean oven
once cleaning is completed and completely cooled down. Turn both knobs off. turn both knobs back to clean and hit cancell button twice. should un-lock then
Dec 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
310 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
