Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My mobile after uninstall one program didnt comes up the logo comes but when need go to windows its freezed what can i do?
Desinstaller toolbar ask
I tried to post this in Spanish for you, but the FixYa website won't allow it, so here's the English version:
How do I uninstall the Toolbar?
You can easily uninstall the Toolbar using the instructions below:
Windows XP:
  1. Close all open Web browsers
  2. From the "Start" menu in Windows, select "Control Panel"
  3. Select "Add/Remove Programs"
  4. Select the program with the Ask logo and the text "Ask Toolbar" (or our partner's brand for a custom Toolbar)
  5. Click "Change/Remove"
Windows Vista:
  2. From the "Start" menu in Windows, select "Control Panel". Under the "Programs" icon, select "Uninstall a program"
  3. Select the program with the Ask logo and the text "Ask Toolbar" (or our partner's brand for a custom Toolbar)
  4. Click "Uninstall" and then "Continue" to remove the Toolbar
Windows 7:
  1. From your computer's 'Start' button, select 'Control Panel'
  2. Click the "Uninstall a Program" option found under the "Programs" category
  4. Click 'Remove'
You can also uninstall the toolbar directly from the toolbar
  1. Click on the chevron (down arrow) on the Option button on the toolbar
  2. Select "Uninstall" from the drop down menu
  3. Click "Yes" when asked "Are you sure you want to uninstall this product"
  4. Close all open web browsers
  5. Click "OK" on the popup window
We ask that once you have uninstalled the Ask Toolbar that you reboot your computer to ensure that the uninstall process is complete.
Dec 09, 2012 | Computers & Internet
How to remove deep freeze in the computer
Hi archie,
I see that you want to uninstall Deep Freeze from you computer, See steps below.
  • First open Deep Freeze.
  • On the Deep Freeze window click to select Thawed.
  • Then Click on Apply and reboot.
  • Once the system restarts back up you now go to the Add remove programs or programs and feature to uninstall Deep Freeze from your computer.
  • If you have XP go to control panel then select classic view on the upper left side then look fo Add remove programs then look for Deep Freeze then click on change/remove to uninstall the program.
  • If you have Vista or Win7 click on Start then control panel look for programs and features, this will show you all the programs you have on teh system just like add remove programs.
  • Look for Deep Freeze right click on it then left click on uninstall.
I hope that this will help you uninstall your Deep Freeze program from your system.
Thank you for choosing Fixya,
mvincent
Apr 25, 2011 | Computers & Internet
My LG mobile keeps saying maximum number of applications reached each time i try and send a text HELP
That means there isn't much memory left. You will have to delete some applications:
The uninstall processes on LG Incite mobile phone are not complicated, three ways you can choose below according to situation/setup. LG Phone Problem and solution
1. Uninstall Apps Using ActiveSync LG-Incite info
For Windows XP and below users will want to use the ActiveSync program. You can download ActiveSync 4.5 here.
Once downloaded and installed on your desktop ActiveSync uninstalls are one of the easiest ways to remove unwanted programs, simply follow the directions below:
  1. Connect your LG Incite to ActiveSync
  2. Click on the "Tools" option
  3. Click Add/Remove Programs
  4. At this point you'll see a screen that lists all of your devices programs, each program will have a checkbox to the left of the programs name and all of your programs will have a checkmark located next to their names.
  5. Take out the checkmark in each program box you'd like to uninstall.
  6. Click "OK"
It's really that simple, your LG Incite will take a moment to uninstall the unwanted Windows Mobile Apps you chose and then you're done.
2. Uninstall Apps Using Windows Mobile Device Center
If you're a Windows Vista desktop user there's no reason to download ActiveSync, partly because it won't work, but more importantly because Windows Vista comes standard with the Windows Mobile Device Center, a device to desktop sync application that functions in much the same way as ActiveSync 4.5.
Uninstalling Apps with Windows Mobile Device Center is a simple process if you follow the quick steps below:
  1. Connect your LG Incite via USB to your desktop to launch the application.
  2. Click on the "Programs And Services" option
  3. Click the "More" option, You will now see a program box similar to the one found with ActiveSync 4.5.
  4. Each program will have a box with a checkmark, find the programs you'd like to uninstall and uncheck that box.
  5. Click "OK"
The unchecked programs will now uninstall from your device, its really that simple.
3. Uninstall Programs Directly From Your Windows Mobile Device.
You don't have to use a computer to delete programs from your LG Incite, if you're on the go uninstalling apps directly from your system once again involves only a few quick steps.
  1. Go to your "Start" button
  2. Go to "Settings"
  3. You'll see a "System" tab, click on that tab.
  4. Then go to "Remove Programs"
  5. Choose the Application you want to remove and highlight it.
  6. Click "Remove"
Your LG Incite will now remove the highlighted application.
Personally I usually use my computer for deleting apps just in case anything goes wrong during the uninstall process, however i've rarely heard of people running into Windows Mobile uninstall issues when doing so from their devices.
Conclusion
The 3 uninstall options listed above are the easiest ways to uninstall apps from your Windows Mobile based Pocket PC and Smartphone devices.
If these steps don't work your best bet may be to use the "Clear Storage" option on your Windows Mobile device and start your device with the standard fresh install, but hopefully it doesn't come to that."
Feb 28, 2011 | Cell Phones
How to uninstall deep freez from my pc
If you cannot uninstall the application from "Add/Remove Programs" then you will need to get "Microsoft windows installer Cleanup Utility" from the M/S Website... install that, and remove deep freeze from the list that comes up when you launch the cleanup utility.
May 14, 2010 | Computers & Internet
How to uninstall deep freeze version 6.53.020.2763 ? i can't find the uninstaller for this program anywhere in my pc. thanks in advance.
source(http://tricks-collections.com/uninstall-deep-freeze-60-without-password/)
Smart Software for Deep Freeze v.6 to disable or uninstall this software in this time there is no. But with little tricks, Deep Freeze 6.0 can be disable or unintal not requiring password. following way to disable or unintal Deep Freeze ver 6 :
  1. Booting Computer From CD use Windows XP Installer
  2. After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  3. then selected R to repair Windows ( Repair Setup)
  4. Hereinafter continue Install windows untill finish.
  5. Now prepare the Deepfreeze v.6 of and double click
  6. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
  7. Done……
Apr 21, 2010 | Computers & Internet
I want to uninstall deep freeze.
first close all programe is runing
then goto start - setting - control panel
a window will display from there select add or remove programe another window will display and where you can see the all software installed in computer. then select deep freeze & click on change or remove button. your software will uninstall
thanks
Mar 26, 2010 | Computers & Internet
How to uninstall a program from windows vista
two ways.....
....1. Click "Windows" logo -> computer -> it will be on the top bar "Uninstall or change a program"
....2. Click "Windows logo" -> control panle -> Uninstall a program or Program and features (depends on Vista or Classic view of control panle)
Nov 11, 2009 | Dell Computers & Internet
Want to rid computer of freeze.com
ok IE Uninstall Instructions for the Freeze.com Toolbar.
  1. Click on the Start button for your Windows operating system.
  2. Click on and open the Control Panel.
  3. Click on and open Add or Remove Programs.
  4. Find the program titled Freeze.com Toolbar.
  5. Click on the Change/Remove button.
Performing these steps will uninstall the Freeze.com Toolbar and remove any files associated with the program.
Firefox Uninstall Instructions for the Freeze.com Toolbar.
  1. From the Firebox menu bar, click on Tools.
  2. Select Add-ons from the drop down menu.
  3. The Add-on screen will open.
  4. Click on the Extensions button.
  5. Click on the Uninstall button for the Freeze.com Toolbar.
Nov 30, 2008 | Microsoft Office Standard for PC
Deep freeze
hi.. ! i am working in internet cafe , from yestarday hotmail is not working they say you have to install new version of windows massenger. i can install the new version of windows live .but i have deep freeze in my every computer.but i can't see the deep freze icone in my textbar its show but when i go to put mouce corser its desapiar i wnat to disable the depfreze .pliz help me any one.. what sholud i do ..? and when i try to reinstall the deep freez then computer says " disable first the allraday insatall deep frezz , pliz help me. thanx.
Mar 03, 2008 | Computers & Internet
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
