Question about SanDisk Sansa e250 MP3 Player
My sandisk wont cut off snadisk keeps flashing across the screen. And it says No songs.
    President:
  • 803 Answers
Try resetting it:
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
If That does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 01, 2009
How to unlock snadisk pendrive
This link may help
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
Apr 04, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 2gd snadisk flash drive, when i insert it in usd port, red light blinks for few seconds and then turns off. flash drive is not deteted by windows.
Have you made any recent changes to your computer hardware - new USB ports/hubs?
There may not be enough power getting to the drive for it to power up correctly.
Hope this helps.
Dec 14, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Need unlock code for 1gb snadisk micro sd. Put memory card from 1 nokia 6085 to another 6085 and now its asking for a memory card pass word i never set
some of the SD cards have a micro lock switch on one edge... check that first... it may be in a locked position.
You could also put the card in another device such as a reader so you could manipulate it from your computer directly to remove any files and then reformat for your camera...
K
Sep 08, 2009 | SanDisk 1GB microSD Memory Card
Deleteing skip songs
Does the message "no songs" appear in your screen ?
There are possible corrupted files on your player.
Try next site: http://kb.sandisk.com/app/answers/detail/a_id/3
It tells you: 1. How to make a backup. 2. How to do a format.
Aug 10, 2009 | SanDisk Sansa e250 MP3 Player
Dont understand y my sandisk wont play my videos
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="120" height="47" id="help_black_widget" align="middle"><param name="allowScriptAccess" value="sameDomain" /><param name="movie" value="http://www.crossloop.com/widgets/help_black_widget.swf?var1=363524&var2=http://www.crossloop.com" /><param name="quality" value="high" /><param name="bgcolor" value="#ffffff" /><embed src="http://www.crossloop.com/widgets/help_black_widget.swf?var1=363524&var2=http://www.crossloop.com" quality="high" bgcolor="#ffffff" width="120" height="47" name="help_black_widget" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" /></object>
here problems are solved
Feb 20, 2009 | SanDisk 2GB microSD Memory Card
My sansa has black screen!
It's toast, you troll. If you hadn't damaged the screen, you might have been eligible for an in-warranty replacement, but now you're screwed.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 25, 2008 | SanDisk Sansa c200 MP3 Player
The screen
Attention: Resetting the device will delete all the songs..
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jun 07, 2008 | SanDisk Sansa c240 MP3 Player
My Mp3 wont play certain songs
Sounds like you have two problems here. First my guess is your files bought from walmart are corrupted some how. just delete the ones that are giving you fits and call it a day. Second you mentioned it wont even sync music,,,, Are you saying none of your music or just the walmart ones ?
Nov 17, 2007 | SanDisk Sansa e260 MP3 Player
E270 - white across top of screen - menu won't come up
Hey scoob, I have 3 of these players in my home and every time there is a problem with them we find that if we HOLD the power button in and keep it in until it shuts off (while the button is still pressed)... can take a full minute or more, it seems to reset any problems we have encountered. worth a try
Jun 10, 2007 | SanDisk Sansa e260 MP3 Player
Can't delete songs
The sansa has two USB modes. If you load tracks in one mode you have to be in the same mode to see them in explorer and also be able to delete them. Took me ages to figure this out. From the main menu, go to Settings then select USB and toggle between "MSC" and "Auto Detect". You should then be able to see the hidden tracks. I have firmware 2.2.5A installed so you might want to check that too.
I now only use the Sansa in MSC mode as it seems to crash Winamp if I use it in Autodetect.
May 02, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
