Question about Poulan Pro Chain Saw 46cc 20"
Will not start has petrol and spark
The saw is a Micro 25 Will not start it has petrol and spark
  • 128 Answers
Cheak your air fiter. It could also be one of the jets are plugged. Replace spark plug just to be sure
Posted on Sep 30, 2009
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
CHAIN SAW HOMELITE FUEL
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
Sep 15, 2012 | Homelite Garden
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
When i try to start it it fell to start
There are two common problems - fuel starvation and spark. Firstly, take out the spark plug and earth it to the body of the saw with a pair of insulated pliers, pull the cord and see do you have a strong blue spark. If you do, put five or six drops of petrol into the cylinder, replace the spark plug and pull. If it starts briefly, you have a fuel starvation problem. Good luck!
Aug 13, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not start.got gas and spark.loosenthe gas cap firer but would not stay running.thank you.
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Aug 13, 2009 | Poulan Garden
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Petrol leak exhaust
the unit is flooded...pull the spark plug and turn the unit over a few times to help dry it out.problem is that the crank case is also full of fuel.you can turn the unit upside down for a day to help the fuel out.install new spark plug,don't choke it,pull the trigger to full throttle pull the recoil ten times this will pull the fuel up to top of cylinder.remove spark plug pull a couple times and reinstall the spark plug.start the unit. if the unit floods again you have carb troubles.the needle is stuck open letting in too much fuel and it needs to be replaced.let me know if this helped.
Mar 11, 2009 | Husqvarna Chain Saw 20" Bar
Change Spark Plug on Eager ****** Chain Saw
yea you have to take it apart sorry
Oct 06, 2008 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
81 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
