Question about Fuji FinePix F40fd Digital Camera
What does Frame No Full mean?
What does Frame No Full mean as it seems to be preventing me from taking any pictures and I don't know how to get rid of it. Have tried deleting lots of photos but still not working
  • 244 Answers
If you look at the top right of your camera screen when reviewing pictures you should see the frame count. As yours is reading "Frame number full" the count should be reading 999.9999 so you need to reset to 100.0000. How to do this is posted in my tips section of my profile under "THE ONLY WAY I KNOW HOW" I have pasted the section below.
Cheers
FRAME NUMBER FULL!!
If you get this message on screen then your counter has reached 999-9999 and the camera will not take anymore pictures until you reset the counter to 100-0001.
To do this follow the instructions in your manual or read on my friends...
Firstly, make sure you have a picture card inserted into your camera and you have saved any pictures on it to your pc because you are about to format the card inside the camera and you will lose any pictures you have stored on there.
Ok. turn your camera on and press the menu/ok button and select "SETTINGS" from the menu.
Scroll through the menus until you find FORMAT. Select this and you will be asked if you would like to continue. Select OK.
Depending on how large your card is (16mb - 1,2 gb etc) will determine how long this will take but it's not very long.
After you have done this your card is now wiped clean of memory and has been formatted to be used for your cameras software.
Next, select FRAME in the SETTINGS menu and set your camera to RENEW and press OK.
Now come out of your menus and take a picture.
Review the picture taken and check the counter reading in the top right of the screen. It should now read 100-0001. The counter has now been reset.
Now go back into your menu and select SETTINGS again and scroll down to FRAME once again. Set this back to CONT (continuous) and press ok. Your camera should be reset and you can now use it.
Note: If you have more than one card you will have to reformat each card because the camera will store and recognise the frame numbers stored on the card and continue using them rather than set them to 100-0001 or will open a new folder on your card and start using this as the new one thus taking up more space on your card reducing the number of shots you can store on it
Posted on Sep 30, 2009
I have a black frame around the tv picture.
Go into Settings and play with 'Aspect Ratio'. Remember though, not all shows are made in Widescreen format, and certainly nothing made older than 10 years ago.
Mar 30, 2017 | Televison & Video
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 | Cameras
LG900G - got it yesterday. Everything seem to work up until today. Think at first Handheld memory was full when i tried to snap a pic. I deleted all the pictures i took earlier and now when i try to take a...
I'm having the same problem. It will still allow me to take video though. I don't know what's going on. I've cleared out my memory, and checked it under settings. Almost all of my memory is clear. I don't know why it's doing that. :(
Aug 09, 2011 | Cell Phones
What does it mean when the camra says frame full
Hi, in most cameras by defult the camera names the pictures it takes in numeric sequence and after a while the range of names reaches an end and the camera would give similar message... if you go to the setup menu look for something like frame number or picture count and see if it is set to continious, see if you can switch it to reset or renew and see what happens... hope that helps :)
Jan 29, 2011 | Fuji FinePix J10 Digital Camera
When i turn on my kodak m1063 my lcd will read that my internal
It is not a matter of downloading the photos. Your camera will say your "memory card is full" when that is needed.
Go into the menu on the camera and scroll down to the Image Storage menu and turn in from Internal Memory to Auto. Should do the trick.
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
!Frame No. Full and cannot take pictures
Well i was just having the same problem and decided to search for an answer. It looks like you might want to reset your camera. Go to menu, set up then click on three and you should find "reset" click that and in no time you will be able to take pictures again!
Mar 21, 2009 | Cameras
Digital Picture Frame Shows Black Bars
The nature of 16:9 basically means that you will be losing photo information in normally framed 4x5/5x7 photos. There is no way to fix this because the frame size of 16:9 is wider than 4x5/5x7. The options the frame offers are the only options to make your photos fit. Either crop, or distort.
The best solution is to keep this in mind when taking photos from now on and assume you will be cropping the top and bottom of the image.
As for the photos you have already taken, the only viable tactic to take is to reframe them for 16:9 yourself. You can download a free photo editing application like "GIMP" to do this. Create a new project that is 800x450 pixels. This will give you a 16:9 canvas. Next drag your existing photos into this canvas and move it around and resize it until you find a suitable framing for your picture.
Unfortunately it seems that as 16:9 solidifies itself as the new screen standard people are finding that shooting photos framed for 4:3 or in portrait dimensions are not translating well to this new standard. You may even want to consider returning this frame and looking for a 4:3 aspect ratio frame if cropping/resizing is not acceptable for you. Good luck!
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Full frame??
Hello to all. Well after a few tries I figuered it out, all you do is hold down the arrow pointing > to the right at the back and thats it full screen, I guess pressing the arrow < pointing to the left reduces the size again. Just remember to hold it down for a few seconds.Hope I was helpful, take care all.. Happy Holidays
Dec 14, 2008 | Coby DP-768 7-Inch Widescreen Digital...
Finepix s700
I had the same problem. Once it said "Memory Full" there's no way to get rid of it how much you try to recover, format the card, reset the camera with no avail. I had thought the camera was out of order. Then googled around and come across with this workaround. When nothing else works for you just take out the memory card. Take a picture to the internal memory of the camera and then insert the card. Voila!! you can enjoy our camera. I guess this is a software bug. The camera can not reset the memory card full flag before you take a picture to the internal memory.
I hope this helps.
Mar 20, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix F40fd Digital Camera Logo
1,323 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
