Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WD640 Washer Dryer
Every time I try to use my machine on any cycle the work test comes up on my display screen. How do I turn off the test mode?
  • Anonymous Dec 29, 2007
    the test mode is on but despite trying to press the buttons together for 10 seconds to clear it, the wash programme does not come on and the machine reverts to test
  • JKGA Jan 09, 2008
    Whichever programme I turn the machine to, as soon as I press start the display changes to 'Test', works through the cycle perfectly, dry, and very quickly. It then stops, clicks the door lock off, then starts up all over againg, on test.
    How can I get out of this and start to wash?
I had a similar experience.  I had to try a few times - it has to be EXACTLY together and then the magic "doff" shall appear and save the world.
Posted on Jan 12, 2009
    President:
  • 1,294 Answers
Your test mode is on, maybe accidently. Press "start", "cancel" OR "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 29, 2007
I have somehow managed to put my hotpoint aquarius into test mode
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Im getting test coming on display
try this - press start, press start again. Now press the on/off button and the start button at the same time and hold them down for 5-10 seconds until the display shows d-end or d-off.
Oct 31, 2009 | Hotpoint Aquarius WD640 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Where do i Find the heating element on my wd640 washer dryer
on top of the drum there is a metal dryer box. the heating element is connected by 2 wires.
it maybe that a build up of lint has tripped your thermal wire out or the thermistor,(you will have to test the continuity).
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
Test display
hi there let your machine do the compleat test cycle again then when it gets to the end press and hold the start/cancel button and the on/off button at the same time for at least ten seconds.
hope this is of some help
Dec 14, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
241 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
