Question about Pyle PLHR9TSB Car Monitor
The usb input plug on the rear of the screen inside the unit has come apart i need to know which colour wire connects to which pin in the plug on the screen circuit board thanks i have the following wires 1x thick black 1x red 1x white 1x green 1x thin black
  • 3 more comments
  • sales85 Sep 30, 2009
    that first picture is of the usb plug that connects to the pc/laptop
    my problem is internally with the screen
    it is a 5 pin plug i will mail you a picture shortly
    here is a picture of it for you (if you cannot see it then i may need to e mail it direct to you if you supply me with an e mail address)
    [IMGhttp://i38.photobucket.com/albums/e112/K...[/IMG]
    you can see the white 5 pin plug at the bottom right and to the left you can just make out the 5 cables
    the thick black wire i must imagine is for the shielding
    thanks for the help so far i cannot test it till this evening as the customer is at work and his vehicle is locked up at his house i will let you know
    plugged it in and so far it seems to work
    however the customer just needs to figure out how to get the touch screen to work
  • sales85 Oct 13, 2009
    no joy the touch screen still does not work
    thanks for the help but need to get a new one
    President:
  • 1,723 Answers
I have the four wire connection, not sure what the other black is for, are you sure you need it? USB is 4 wire
Posted on Oct 13, 2009
  • 2,841 Answers
  1. Red
  2. White
  3. Green
  4. Black
    President:
  • 1,188 Answers
The following diagrams can help you. I can tell you which wire connects where if I have a current photo of your screen. Let me know if you want more help.
There are only four wires in a USB. Let me know if you think that your connector has more wires.
Posted on Sep 30, 2009
  • 4 more comments
  • Adnan Bhatti
    Adnan Bhatti Sep 30, 2009
    The thick black wire is for shielding the current signals.
    From your diagram, it appears that the configuration is:
    THICK BLACK, RED, WHITE, GREEN, THIN BLACK. (from left to right)
    Try it and report back.
  • Adnan Bhatti
    As a test, there is
    +5 V DC present between the terminals for red and thin black wires.
    Use a mulitimeter to check the voltage. Insert +ve terminal inside the left most terminal of the connector on board. Insert the -ve terminal of the voltmeter inside the second-to-the-right-most terminal and you should have
    +5 V DC.
    You will need to supply power to the board to perform this test.
    Also, look closely at the connector joints. Two of the connectors my be connected together.
    Please let me know your findings.
  • Adnan Bhatti
    If the first wiring order did not help then it must be this one:
    RED, WHITE, GREEN, THICK BLACK, THIN BLACK.
    OR
    THIN BLACK, THICK BLACK, GREEN, WHITE, RED.
    The multimeter should report + 5 V DC between thin black and red wire terminals.
  • Adnan Bhatti
    I will be waiting for your reply.
  • Adnan Bhatti
    Can you please elaborate on your problem? Your problem was initially about how to plug-in the USB. Now you state that the connections are OK. If the connections are alright then the touchscreen should work. Please elaborate.
  • Adnan Bhatti
    Adnan Bhatti Oct 13, 2009
    What is the problem now. Were you unable to connect the wires correctly?
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
I have a BOSS BV9970 stereo. the usb will not let me play my ipod, it starts to load it but stops halfway through. and when i try to use the aux, my right rear and right front speakers will not play.
sounds like a loose connection on the aux input. boss has a pretty bad reputation for there usb / aux connections inside the unit. also if your right rear and right dont play on anything its bc you have them turned down. or if this is recently installed they got mixed up. please let me know more details so i can better help you
Mar 20, 2011 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Pyle PLHR9TSB Car Monitor Logo
220 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
