Question about Epson Stylus CX3200 All-In-One InkJet Printer
Not Printing..... No error message, only a blank piece of paper comes out. So i replaced the ink jets. Its showing that my ink is being used as the level indicater is going down. But still no ink coming out.
  • jbean1
    jbean1 Jan 02, 2008
    Can you put that in English?
Dovrebbero essere le testine di stampa intasate dall'inchiostro essiccato (succede soprattutto con cartucce non originali). Prova a smontare le testine, e tenerle a bagno per una nottata in un solvente specifico (io ho usato del semplice acetone ed ha funzionato). Quindi imbevi nell'acetone un capello (non è molto elegante, ma funziona) e cerca piano piano di inserirlo nei micro fori presenti sulle punte che forano le cartucce di stampa fino a che non risulteranno pulite. Quindi rimonta il tutto ed in bocca al lupo.
Max
Posted on Jan 01, 2008
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
The printing is running normally but the paper is coming out blank, no light , no codes. I run the power cleaning 3 times already, can you tell me what to do?
Remove the cartridges and hold a piece of tissue paper under the jets to **** ink through them. If this does not work, stand the cartridges in about 1/4 inch hot water for a while to soften dried ink. (if they are new cartridges, did you remember to remove the seal over the jets?)
Jan 24, 2011 | Epson Stylus CX4800 All-In-One InkJet...
When printing colors, they show up light with lines in the color areas. No error messages show up when troubleshooting. Replacement of ink cartridges did not help. Cleaning print heads did not...
You have blocked jets in hour cartridge, Try running the cartridge cleaning utility that should be part of the printer software, if this does not work try leeching the the jets clean by holding a piece of tissue paper over the jets, as a last resort stand the cartridge in a saucer of hot water for a while. Run the cleaning sequence again and hopefully you will have a clean print.
Jan 18, 2011 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Paper jam problem fixed after removing toner and removing paper, but also now getting auto showing as well and ready and the cartridge ink levels. Auto not their before and now not printing. No errors...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever. Check the following video hope this helps you.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Aug 26, 2010 | HP LaserJet 2840 Printer
My problem is my printer is showing paper jam but there no paper.
Hello there
Ok it only a try.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 06, 2010 | HP J4680 Office Jet All-In-One Printer
I try to print but the paper comes out blank, I just bought the cartridges today, but I really dont know what happenes.
If you've replaced the cartridges and still the printer comes out with blank paper, then what has happened, depending if it is an inkjet or bubble jet, is that the pump or heating element (in a inkjet it is a pump and in bubble jet the ink is heated up in the tank to produce bubbles of ink that transfer to the paper. When you do get a replacement, hold up a piece of paper printed from a bubble jet printer.
If the printer is not under warranty, then don't bother for the repair.
If it is a laser printer, what may have happened is the wire that charges to the drum in transferring the image to it is not working.
Aug 21, 2009 | Office Equipment & Supplies
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Jun 11, 2009 | Epson Stylus C46 InkJet Printer
Sounds/looks like it's printing but paper comes out clean - there's lots of ink and I've changed the ink levels
Hi, have you checked to make sure you removed the sticky tape cover from the end of the cart?
Sounds silly I know but I have done this before & it's easy to forget when your in a hurry :-)
Cheers
Sham
Jun 01, 2009 | Canon Bubble Jet i80 InkJet Printer
Foam piece ripped now feeder doesn't work
It'd be cheaper and easier to get a new printer. Most modern desk jet printers are sold as throw-aways. There are few if any replacement parts for them.
Dec 02, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
409 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
