Question about Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
It doesn't do that with the color cartridge. I have cleaned everything possible. It just dones't print. I have had that pb each time I have changed a black cartridge, and eventually, it would kick in but no clue why. And right now, I am stuck and I need to print. thnak you.
    President:
  • 1,653 Answers
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Posted on Sep 30, 2009
SOURCE:
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Colourcartridgenotprinting
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:
1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
If that doesn't help but you're using genuine Lexmark supplies, please contact Lexmark Technical Support for additional assistance, otherwise, please replace your color cartridge with a genuine one.
Dec 12, 2011 | Lexmark X2670 All-In-One Printer
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
I changed the printer cartridges in a hp officejet 4315 and now it won't print-flashing error meesage "Cartridge Error:refer to device documentation to trouble shoot" What do I do? i
Good Day Sir, hope this will help you.
print cartridge troubleshooting for hp officejet 4315 :
1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles.
2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket.
3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side.
4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges.
5. If the self test report shows a problem, clean the print cartridges.
6. If the problem persists, clean the copper-colored contacts of the print cartridges.
7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
have a nice day.
7.
Jun 22, 2010 | HP Officejet 4315 All-in-One Printer
New black installed; will not print in black ink. Everything else prints!
hi, it is possible that the black cart was not installed properly. Try reseating the black cart and see if it works. You can also try to calibrate the printer. you can do this by pressing the menu button then go down to calibrate printer. after that it would also help to perform a deep clean which can also be found on that same menu. then try to print. If all these fails, try to call the kodak hotline 800.421.6699
Oct 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black cartridge problem
Hi , good day , try to do head cleaning until the black print will appear perfect in color.
May 05, 2008 | Epson Stylus Color 460 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
4,266 people viewed this question
Clive
Clive
old marine
old marine
