Question about Zodiac Pacer Pool Cleaner
My Zodiac Pacer seems to get stuck. There is suction (pretty strong). It can happen on the side or floor of the pool. If I pull it off, it starts going again, it's like there's too much suction or something. Please help.
  • M1lo Oct 02, 2009
    I removed and checked the diaphragm and it looks fine. I took it to the pool shop to be sure, they comfirmed it was fine. Still can't figure out why it's sticking...
  • M1lo Oct 04, 2009
    Thanks for the reply. There is a valve and I tried it on all 3 settings, and it doesn't seem to help. I'll check the manual again.
  • 990 Answers
It probally is to much suction. You should have a dirveter valve where it hooks to the wall or the skimmer. This should have come with the unit and your manuel should describe it and it's function for you. if you don't have one your local pool store can help you out as these are generic in most case's.
Posted on Oct 03, 2009
Testimonial: "Thanks for your help!"
Hose Collapses at skimmer
There are a few reasons the hose will collapse. One thing is for sure you will need to replace any sections that have collapsed because they will continue to collapse now that the integrity of the hose has been breached.
  • The suction is too strong.
  • There is something stuck in the head of the cleaner. acorn bottle cap etc...
  • The hose is just old and needs to be replaced.
Here is a good resource for pool cleaner trouble shooting.
http://www.troublefreepool.com/archive/index.php/f-50.html
Jun 10, 2015 | Zodiac Pacer Pool Cleaner
How to adjust suction when using the barracuda pacer
these units come with a flow meter and adjuster. if these parts have been lost/damaged, you can replace them at a local pool store. also, keep in mind that as the filter becomes dirty, the flow will decrease and affect performance
Jun 18, 2014 | Zodiac Pacer Pool Cleaner
How to adjust suction in a pacer
There is a special adaptor that is put between the cleaner and the suction port. It allows you to adjust it so there will be max suction (only sucking thru the unit) and less suction by opening a window to allow suction from outside the unit/at the exterior of the adaptor which less suction will be thru the pacer.
Zodiac Pacer getting stuck near lower steps in shallow end of pool.
There are several things that you will want to check if these pool cleaners are becoming hung on your pool steps. make sure that you are utilizing your return flow. If the return jets are not positioned properly, it will cause issues with steps. Position the return line directional so that you can only detect water movement on the surface 8 feet out from the wall, and aim it at the center of the opposite wall. In addition to your return lines, you will also want to confirm proper hose length and weight. Make any adjustments to the flow needed if it is too strong. If these options don't work, you will need to install a wheel deflector (#W69647).
Dec 29, 2010 | Zodiac Pacer Pool Cleaner
Zodiac pool cleaner stops and starts and sometimes just stops working completely. Checked diaphram. replaced it with a new one. pool is forever getting green ... at my wits end... bout to pull my hair...
With these pool cleaners, there are several things that can cause a lack of suction and movement. Make sure that the main drain and all suction lines are closed except the line you are using. Make sure there is no debris in the flapper or filter that could be clogging suction. Check the hose are ensure that there are no leaks. Check the pump basket for looseness, cracks, and worn or missing o-rings.
Aug 21, 2010 | Zodiac Pacer Pool Cleaner
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
I have a baracuda pacer pool cleaner and it seems to run in the same direction and doesn't clean the whole pool how do I solve the problem
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Apr 19, 2010 | Zodiac Pacer Pool Cleaner
Barracuda Pacer comes right up the side and above waterline then sucks so much air, pump has to be reprimed. Really annoying
You just need to slow the cleaner down and dirvert some suction away from it. It should never really come anymore than 1/3 the way up the wall.
Mar 29, 2010 | Zodiac Pacer Pool Cleaner
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
520 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
