Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
GFCI alarm stays on
I had my spa turned off over the summer. I filled it with water and turned on the breaker and my GFCI alarm stays on. The tub had water in it all summer. I drained it and refilled it. I turned on the breaker and the GFCI alarm stays on
  • 990 Answers
Open your drain valve under the unit to break any air lock that will have gotten there when you drained the tub.
Posted on Oct 03, 2009
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Why can't I use a gfci breaker my for sauna heater
26 Installing two pole GFI breaker
I'm not clear on why you can't use a GFI Breaker. Has someone said this to you, or have you tried using a GFI and it didn't work? Does the heater run off 120 v or 240 v?
May 31, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
My spa depot hot tub keeps popping the breaker
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
What type breaker?
GFCI or ordinary heat-rated breaker?
Do NOT use two GFCIs on same circuit.
Spa needs GFCI to protect people while immersed in water.
You might have dangerous short, or leaking element, bad switch, bad wiring, bad electrical connection, or undersized wire and breaker.
If breaker is undersized for load, it can get loose on the busbar and then start arcing, and then tripping. Use nose to smell for burning. Feel breakers to see if they are warm. Move wire to different same-size breaker.
Mar 18, 2013 | Pool & Spa
The breaker for my hot tub will not stay on. Could the breaker be bad?
Circuit breakers do wear out. The GFCI could also be bad. If it is neither of those the Hi Limit sensor may have failed, it is a safety switch which prevents normal operation of the spa if not functioning correctly. There could possibly be another electrical fault, the heater element could be compromised.
Sep 08, 2012 | Pool & Spa
Hot tub trips gfci
spa may be leaking water internally check to see all grounds are hooked up . or you might have a bad gfic
Sep 06, 2012 | Qca Spas Pool & Spa
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
145 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
