Question about HP Computers & Internet
I have 2 batterys that are the same and 1 seems 2 be about 15-20% compared to my other battery??? It may last ten mins until dead but my other one may tast an hr or 2? before it is dead? any ideas 2 restore battery life???
  • 10,865 Answers
Your short lived battery is almost worn out. there is no safe way to revive it; your best off to replace it.
Posted on Sep 30, 2009
Parked my Truck the next morning it was dead , what could be draining my batteries
Could be anything in the truck. The best way to narrow this type of problem down is to due a parasitic draw test. This is done by disconnecting the ground from the battery. Then connect an amp probe inline between the battery and terminal. Watch the amperage on the meter, it should drop to 5 ma or less after 10 min. This is sleep mode. If this happens you either don't have a draw (drain) or you have a draw that is that can't be duplicated at this time. If your amp draw is still over 5 ma after ten min. Something is staying on. To find out what that might be. Without opening any doors or actuating any switches, start removing and replacing fuses while watching amp draw on the meter when you see the amp draw drop you have found the circuit that is draining the battery. Hope this helps.
Oct 02, 2016 | Cars & Trucks
Bypass security for 1999Yukon ,I put a new egnitiontumbler and security don't let truck run shuts off qwik can I bypass this?
Try touching the positive and the negative battery cables together and then hooking them back on battery then this is important 1-- unlock with key (if not locked lock it then unlock all doors with key leave doors open and put key in try to start leave in the on position for ten mins until light stops blinking then try starting it again if it don't start then leave key in on position wait ten more mins and start truck as always hope this helps good luck
Feb 16, 2015 | Cars & Trucks
Battery is ok but now its dead .car gages shut down while driving then moter dies out .starts with a jump but only last for about ten min. would a sensor be causing this? or is the acura 1999 tl .telling...
how about a new alternator ,the old one is not really repairable for the home owner ,start engine and then disconnect battery if engine keeps running then its the battery if it stops then its the alternartor
Aug 18, 2011 | 1999 Acura TL
I have a 1996 Concorde with the 3.5 L EGJ V6 engine. last week when driving it the lights started to dim..until i pressed on the gas..then they would last a min or so and dim again. then the abs light went...
Sounds like the alternator is not fully charging the battery -- could be faulty alternator (including faulty voltage regulator), or just bad connections between battery / alternator / ground.
More info, please let me know.
Charlie
Feb 27, 2011 | 1996 Chrysler Concorde
2002 Gmc Yukon xl. Drove it one morning and returned home than ten mins. later went to start it and nothing. Dead. Turn key to on and all dash lights go our and nothing. Doesnt crank or anything. ...
Take the battery out of it and go to a auto store to get it checked, they do that free, but you might need to get it charged or get a new battery. If it clicks then it's definitely the battery, otherwise it could be something completely different.
Things to consider
-oil change?
-last tuned up?
-battery age?
-Alternator?
-check fuses?
-are you aggressive while driving it, that can cause internal engine problems over the years.
hope it helps.
Dec 12, 2010 | 2002 GMC Yukon XL
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
