Question about Canon Pixma iP4500 InkJet Printer
Ip4500 - orange light flashes four times! - Canon Pixma iP4500 InkJet Printer
    Guru:
  • 389 Answers
* For printer, using inkwells BCI-24, mistake, as a rule, is connected with that that inkwell is inserted not before the end and prevents moving the carriage. The Sensor of presence of the inkwells beside these printer no. The Amount of the ink pays the software driver of the printer.
** or printer has defined that is installed already used (devastated in him) картридж. Striking the PRESENTING (Resume\Cancel) will allow to throw the mistake and continue the seal.
*** the inkwell is installed after her(its) use again or inkwell is installed not in its cell. Or inkwell is not recognized (the led in inkwell does not glow). Or amount of the remained ink unknown . For continuation of the seal with fuelled by inkwell press PRESENTING (Resume\Cancel) more, than on 5 sec. The Printer will remember that was used fuelled inkwell and will disconnect the function of the determination of the remained ink.
In printer, using inkwells BCI-3/6, presence of the ink and inkwells is defined оптопарой, located in carriage under blank wadding by part of inkwell, for what in day by blank wadding of the compartment of the inkwell is formed reflecting prism.
Posted on Sep 30, 2009
Flashing orange fault flashes four times whirlpool
4 flashes on whirlpool diswasher usual means a draining problem clean out your filters
Feb 02, 2014 | Whirlpool Dishwashers
My IP4500 orange lights blinks 15 times. How do i fix this
Hello!
Please check your printer LCD. You may see some error on your printer LCD code that Error Number and send back to me. I will try to solve your printer as much as I can... thanks
Sep 11, 2011 | Canon Pixma iP4500 InkJet Printer
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
Just stopped working, orange light flashing
  • If it flashes orange five times consecutively, that means there is a print head error.
  • Reseat the print head, then reset the printer.
  • To reseat the print head, make sure the printer is on.
  • Open the paper output tray and top cover.
  • Make sure the print head holder is in the center and open the inner cover.
  • Remove all the ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Reseat the print head and lock the lever.
  • Replace the ink tanks.
Jan 30, 2011 | Canon Pixma iP4500 InkJet Printer
I put in a new ink and my canon ip4500 came up with service error 5c20 and the orange light started flashing how can i fix it?
It has not detected the cartridges correctly or it has a waste ink problem, not sure which. Are they genuine Canon carts? I hope this helps will you let me know how you get on please?
reseat all the cartridw0zz_3.jpgges and read the attached which should work with the 4300 (thanks also to tech1569 for this)
Jan 26, 2011 | Canon Pixma iP4500 InkJet Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
Hi, i geting problem in inkjet printer connon
These are the instructions which worked for me on my Canon pixma ip470 bought August 08:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.
Jan 08, 2010 | Canon Pixma iP4500 InkJet Printer
Hi, My Cannon IP4500 has been working fine but it now flashes the green power light and orange warning light alternately when turned on. The orange light flashes twelve times then it momentarily pauses and...
Hai
If its trying to make some mechanical sound, try putting some A4 size papaer in the tray so that to finish any incomplete printing work.
Rabby
Jun 15, 2008 | Computers & Internet
Canon Pixma iP4500 InkJet Printer Logo
733 people viewed this question
old marine
old marine
