Question about Samsung LN-S4051D 40 in. LCD Television
Only in black and white - Samsung LN-S4051D 40 in. LCD Television
Posted on Sep 30, 2009
Google com
try to print it white and black or what ever you print make it black and white or white and black and i have a question black and white is color or not?
Nov 16, 2013 | Computers & Internet
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Bulbs blinking fast with light on. it cieling fan has white black green and a black n white wire?does the black and white wire get wired with black or white wire
black to black and white to white. black is hot wire, and white is the nuetral wire. the reason why lights are blinking is there is a watt governor in fan for lights its a little black box. if you remove box, and wire direct for lights. this should take care of the problem. have a good day !!
Dec 12, 2010 | Hunter Ceiling Fan Control Switch
I have an outside light that I want this timer to control. The switch box has a black and a white going out to the light and a black and white with the electricity. The instructions show to hook the red...
You posted under ST01C timer which has 3 wires: black blue and red (no white wire)
Your description seems to say your timer has 3 wires: black white and red
These are two different timers
I'm going to give you two different instructions that are dead-accurate for both types of timers above:
1) Instructions for ST01C and EJ500 Intermatic timers with black blue and red
Lets do the black and white with electricity:
The black Hot wire connects to Timer-black-wire
The white Neutral wire connects to white wire going to Load (to lights)
Now the black and white to the Load (lights)
The black to Load (to light) connects to Timer-blue-wire
The white wires are connected together with wire nut
The red wire is capped off, and used only if you have 3-way switching.
Green connects to bare ground
2) Instructions for all in-wall timers with black, red and white wires (except Aube series timers)
Lets do the black and white from electricity
The white Neutral connects to Timer-white-wire and to white wire going to Load
The black wire to Load connects to Timer-red-wire
all three white wires are connected and covered with wire nut
DO NOT CONNECT RED TO WHITE with any model in-wall timer and then turn on power or it can blow out the timer >>> I just did that while experimenting with the Utilitec 0192773.
Red wire goes to Load on all timers, except with Intermatic ST01C and EJ500
Oct 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Samsung LN-S4051D 40 in. LCD Television Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
