Question about Freezers
BEKO TZS490 Hi Can you help my freezer only seems to work in the top compartment which has a fast freeze which works but the rest of the freezer doesnt work?. Compressor must be working to freeze top?. Stat seems to cut comp in and out when adjusted .? Has it lost some gas and only cools top tray.?. Please help
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Posted on Dec 19, 2007
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Hi there my freezer doesnt seem to be freezing properly had water in didnt freeze for 3days in fast freeze also hae ice pos some are freezing some arnt.... 2.5yrs old only plae help
you could try turning up the control to the thermostat to a higher number its likley to ne at the back of the unit try to find it near the compresor or change the thermostat,,as yours is not working right
Jun 24, 2010 | Freezers
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Freezers Logo
377 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
