Question about HP DeskJet 1200c InkJet Printer
Printer does not print
The paper gets jammed every time I start printing on my new HP Deskjet F4288 All-in-one. Sometimes it even happens even the cartridge is being aligned.
  • 4 Answers
Try different paper ,check for any loose parts that may be interfering with paper feed,if theres nothing obstructing it and you have tried new paper ,take it back ,its defective.
Posted on Sep 30, 2009
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Hp 5150 only prints e-mail. When I try to print from Word, a sheet of paper goes into the printer, stops and then I get an message that the printer is out of paper. I have powered down many, many times,...
I had installed a new black print cartridge just before these problems happened. On this HP, when a new cartridge is installed, the printer must go through an alignment procedure and produce a printout in the process. For some reason I did not let the printer do this and that scrambled it's little electronic brains. The troubleshooting section of the printer's documentation recommends not only turning off the printer but unplugging it from its power source as well. Once that was done, the printer went through its alignment function, printed out the obligatory sheet and we were back to normal operations.
Lesson learned - when powering down, always unplug the printer as well as turning it off.
Nov 02, 2009 | HP DeskJet 5150 InkJet Printer
The orange down arrow light keeps blinking. what's wrong?
This means that either the printer is out of paper or there is a paper jam.
Try to check all feeds for a paper jam. Once the jam is cleared your printer should resume printing again.
Sometimes even a small peice of paper can cause the printer jam
Oct 03, 2009 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet F4288
no problem
;just take out the catriges and clean them
;after that plug ou the power cable
:after 30 seconds plug it back in
:nw put in the catriges
:ur problem will get resolved
Jul 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
The printer keeps printing pages of single line code even offline
hi i am having roughly the same problems i use cad and have not even managed to print that far yet what windows are using?
Oct 06, 2006 | HP DeskJet 1100c InkJet Printer
HP DeskJet 1200c InkJet Printer Logo
Seeker5211
Seeker5211
