Question about Sony Cyber-Shot DSC-P7 Digital Camera
Flash does not work. LCD Display only flashes flash sign and gives error code E 01 01
  • 63 Answers
SOURCE: Sony DSC-W50 Flash Error code-E:91:01
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Posted on Aug 05, 2007
  • 74 Answers
SOURCE: e:91:01
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Oct 17, 2008
  • 74 Answers
Press Menu button
togle down thrice from camera to setup 1
If it is working then don't forget to set your Clock.
Posted on Oct 31, 2008
  • 586 Answers
SOURCE: error E:91.01 code flashes on the display,NO flash
Error E:91:01 is for faulty Flash unit, You have to replace FLASH UNIT contains ST Board along with capacitor. The detail of part is given below,
Part No. Description
A-1254-671-A ST-133 BOARD, COMPLETE
Replace the above said part number and your camera work fine again.
Thanks for using fixya.
Posted on Jul 10, 2009
tbreeze47
  • 3083 Answers
SOURCE: E 91 01
Look on google, and you will read about the error code and what it means. Probably a bad capacitor for the flash, but if you quickly turn off the flash in the menu, you can use the camera. If you want to use the flash, you will have to replace the capacitor or have it replaced.
Posted on Feb 15, 2010
Fault code E91-01 and "flash"
Try to turn of the Flash and switch it to normal flash.
Mar 08, 2011 | Cameras
Flash not working error sign E 91;01 on the lcd screen model dscw110
The E:91:01 is the self diagnostic code display of the Camera which indicates the symptom of the issue. This can easily be identified with the help of a authorized service technician.
The E:91:01 code indicates the abnormality of the Camera when the Flash is being charged. Normally this can be resolved by some normal troubleshooting steps and if not changing the Flash unit.
Try recharging the battery in the Camera to Full and then power resetting the Camera. To power reset the Camera, remove the batteries from the Camera, press and hold the power button of the Camera for 30 seconds and then re-insert the battery pack after 1 minute. If the issue persists, try INITIALIZING the Camera. To Initialize, press HOME, select SETTINGS--> MAIN SETTINGS 1-->INITIALIZE-->OK
If the issue persists after resetting and initializing, service may be required to resolve the issue with the Flash unit
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
I am having E:91:01 that pop up on my lcd everytime im taking pictures.
E:91:01 is an error code that indicates problem with flash circuit that is defective.
Replace flash circuit in camera to fix this problem.
Let me know if you need part number info of flash circuit for DSC-W90 or take camera to local camera repair shop to replace flash circuit board.
Thanks.
Nov 15, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Flash won`t work
Error ( E:91:01) is off COMPLETE FLASH UNIT which contains part No. along with description is given below:
A-1166-208-A ST-133 BOARD, COMPLETE
(For DSC-W50)
A-1231-877-A ST-133 BOARD, COMPLETE
(For DSC-W55)
For your convenience please see the pic below of required part:
7985bce.jpg Thanks
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
E:91:01
The problem is with one of the capacitors, Sony can replace it for you at a cost of $80. This error can come, if we click photos continuosly, the capacitor may get heated up. We need to give a gap of 3 to 4 seconds. Time to be given for the flash to get recharged after a click.
Just give a call at Sony help line. 800.222.SONY, they will replace the capacitor.
If its worth the cost, go for the repair, or you can use the device without flash by disabling the flash. At setup just disable the flash and this error wont show up again.
Apr 16, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
E 91 01 THE FLASH DOESNT WORK AND IT GIVES THIS ERROR CODE
Just go in "menu", "set up 1", "initialize", and select "ok". With that you will reestart your camera. I already did it twice in my DSC-H2 and the flash came back to work. Goo Luck!!
Jan 31, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
I get an error message, E:91:01 blinking ,I can't find Reset bottom under LCD cover
Hi!
It's flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 12, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Error E:91.01 code flashes on the display,NO flash either
Jul 10, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Troubleshooting
Its error code E:91:01 corresponds to fault or problem with Flash Circuit. Flash is not working in your camera.
Aug 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Jul 25, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-P7 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
