Question about Xerox Phaser 7700 Laser Printer
Problem printing 1m long paper on 7760
My printer works perfectly until I put the 1m long paper and try to print. First half of the paper is printed correctly, but the other one is not. It looks like the toner hasn't been pasted to the paper. It looks like mess.
  • olix35 Dec 19, 2007
    Yea, very good thinking.
    I'll try to explain further. We are using Mac computers. (PC computer I have driver installed is currently in peaces :) ). When I try to set the paper size (in InDesign) i don't have that size, so I have to make a custom size. In the printer I also have option to set the custom size and I set it, cause there is no fabric setting for that.
    In the printer specification they loud that the printer has the ability to print the paper with 32 cm x 120 cm size. But they force me to set the custom size in the printer. I'm sure I did the right thing.
    I even was able to print that size without problem. But lately...
    Printer is very new, still under warranty. We replaced only one set of toner.
    Thanks for the quick answer!! :)
  • Anonymous Mar 28, 2014
    Toner is on the paper but no words exist
Go to this link, it is for a Different docuprint model, but the setup should be the same. Also Set to thin card stock, will stop your fusing problem, and use standard print mode, unless you have 1GB RAM in the printer.
Posted on Feb 15, 2008
  • 208 Answers
If your driver setting is not set to the proper paper size it will not fuse the entire page.
What you seem to have is a simple setting problem either the machine of the print driver are not set to the correct length shutting the fuser off.
You could have a failed fuser, but if the first half is fine, you have a setting incorrect.
Posted on Dec 19, 2007
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
I replaced a #57 cartridge in my Hp 7760, this AM.Since, it will not run a test/allignment page, nor run anything on paper. Iput the old #57 cartridge back in, rechecked all the cables, still win't print...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 19, 2011 | HP PhotoSmart 7760 InkJet Printer
Xerox Phaser 7760. Set document to print as double sided, and it prints single sided. Printing from Mac. Drivers up to date. Any ideas?
There are a few solutions to this problem.
1. The 7760 does not duplex from the MPT 2. The 7760 will not duplex certain paper types eg. envelope, transparency, labels, thick card stock,special. If your paper type is set to any of these it will default to simplex printing. 3. Conflicts in driver settings will cause the printer to default to simplex printing. 4. From the machine settings, duplex can be enabled or disabled. (Though driver settings should override this).
Hope this helps.
Jan 14, 2011 | Xerox Phaser 7760DN Laser Printer
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
Slow printing
Even though the printer doesn't call for new ink, remove or replace the color cartridge. First I removed the color and the test page printed at full speed. I then put in a new color cartridge and it again worked full speed. I believe the problem was somewhere in the half used color cartridge. Hope this solves your problem.
Jan 26, 2009 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart 7760 printer won't print on colored paper??????
hi icymay,
on photosmart machines you have different trays for different sized media. try placing it on the one for envelops tray or on the regular tray towards the left corner. try copying first if that works try printing from the pc. you may need to change the paper type if it fails to start the print job.
Oct 10, 2008 | Gateway (4000635) Motherboard
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
620 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
