Question about Yamaha HTR-6130 Receiver
No video through VAUX inputs on front of unit
    Sergeant:
    Champion:
  • 232 Answers
Some recievers do have a detection device that will overide the system if something is plugged in the same inlet .
what i mean by that is that if you have already a system plugged in at the back on V AUX 2 at the back , it will automatically override the front input .
try to disconnect the back input and try the front on its own and let me know how you go .
Posted on Sep 30, 2009
Where do i find the sensor for a speedometer on a vauxhall combo van 2002
Most are electrically sent(No cable), look on the top of the gearbox for a small sender unit.
Oct 20, 2014 | Cars & Trucks
Schematic diagram
check the pcb mounted fuses on the power supply board They look like resistors only they have 1 colored stripe. replace the open (resistance above 1 ohm) fuse and enjoy your amp.
Jan 04, 2014 | NAD C355BEE Amplifier
Can't use front panel input and back panle video input has grey picture and no sound
have you tried to remove power from either or both units for a while?
Nov 05, 2012 | JVC AV-20220 TV
Tell the difference between the Aux input and V-Aux input
'Aux' is a general label for any Line Level analog stereo input like DVD, VCR, TV, DBS, etc. They are usually electrically identical and interchangeable except for PHONO.
V-Aux on this unit is on the front panel for conveniently connecting a video device. It has analog and assignable digital audio plus S-video and composite video.
There is nothing labeled 'Aux' on this unit.
Feb 16, 2011 | Denon AVR-2807 Receiver
2003 vaux astra had flat battery now stereo wont work ,shows safe on display
Leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This could take several hours
Sep 11, 2010 | Car Audio & Video
My htr-6090 wont let my dock be on zone2
Zone 2 will only work with an analog signal (RCA) If you use a stereo mini to rca adapter from the ipods headset jack and plug it into the VAux on the front of the receiver it will work. Downside to this is the audio is "dual controlled" Volume from the iPod and Volume from the Receiver. Set the volume no further than 70-75% on the iPod then adjust to taste with Zone 2. Hope this helps
Jun 08, 2010 | Yamaha HTR-6090 Receiver
I can not select input source, even though AV1 is connected. Pressing INPUT button has no effect. All I can see is ''Not connected to the camcorder'', which is true - but I want to record from AV1.
Press INPUT repeatedly to select the external input
to record from.
AV1: Audio/Video Input mounted on back panel.
AV2: Audio/Video Input mounted on front panel.
DV: DV Input mounted on front panel.
DV IN jack.
This recorder is only compatible with DV-format
(DVC-SD, DV25) camcorders. Digital satellite tuners
and Digital video recorders are not compatible.
Make sure your cables are connected correctly, if an audio cable is plugged into the video the unit wont see it.
Sep 05, 2009 | LG RC897T DVD Recorder/VCR Combo
Denon 587 v-aux no video but has sound
try another another source that you know works on the vaux to make sure the input is good. you can try plugging your camera into a diff input or directly to your tv. also make sure to take off the lens cap when you make a video.
Chris B
PHTBA tech
Dec 26, 2007 | Denon AVR-587
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Need help
scan below channel 2 and video should show? Or doesn't it have the audio/video jacks?
Nov 14, 2007 | Zenith C27A24T 27" TV
Yamaha HTR-6130 Receiver Logo
154 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
