Question about Sharp AR-BC260 Color Copier
Reducing How do I reduce a 9x12 document to 8 1/2 x 11?
  • Jackswan Dec 19, 2007
    How do I reduce a 9x12 document to 8 1/2 x 11? I have a Sharp AR BC260 copier
  • Sharp Master
  • 1,113 Answers
Insert original in doc feeder, then select cassette thst has the paper size you require, auto image button appears on display press it and it will self calculate.
Posted on Dec 21, 2007
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
Tip
Valve Pressure Reducing or Pressure Reducing Valve
dfef4ee.jpgThe pressure reducing valve on a boiler is the way that the water pressure in the boiler is controlled. The standard pressure for many hot water boilers is considered to be 12 PSI. To keep the boiler pressure at or near the 12 PSI mark a small valve is used for pressure reducing. Most domestic water systems run between 20 and 60 PSI, so the pressure must be reduced for the boiler.
This pressure reducing valve is installed in the pipe that goes from the domestic cold water to somewhere in the piping on the heating system, usually at or near the expansion tank. The valve is mostly maintenance free but will create some problems at times. Some of the things that can go wrong are:
  1. The valve seat can get dirt stuck under it causing water to leak by and increase the pressure in the boiler, causing the relief valve to release water periodically.
  2. The valve can become plugged with dirt causing the boiler to not have enough water pressure, which will cause circulation problems with the boiler pumps.
  3. The valve can leak causing a mess around the boiler area.
Replacement of the pressure reducing valve is not difficult if the installer strategically placed manual valves so that the reducing valve can be isolated from the rest of the system for replacement.
If the water pressure reducing valve fails in any way, it is usually best to just replace the whole valve rather than trying to repair or fix it. I have tried a number of times with only temporary results. These valves are not a high dollar item and the time it takes to fix them is not worth it.
http://www.fixya.com/support/r3696173-expansion_water_tank_boiler_expansion
http://www.fixya.com/support/r3705970-heating_circulating_water_pump_problems
on Dec 23, 2009 | Heating & Cooling
I am seeing blue lines on the document after scanning
reduce the saturation levels for the blue color if not all the colors. also try reducing the resolution settings for the scans
Sep 07, 2010 | Epson Perfection 1670 Flatbed Scanner
8x10 inch pictures transfer to Photoshop as 9x12 centimeters
open them in some like window pic manger and change the size there then after that up load them to your photoshop
Jun 01, 2009 | Sony Cybershot DSC-H3 Digital Camera
I need some help! If my document holds more than one image the printer prints half of the document and sends through an error message. Any simple solution?
I think you printer's memory has got a problem...Try reducing the size of your pictures using JPEG format.BTW what error messages are you getting. What does it say.
Oct 17, 2008 | Lexmark Office Equipment & Supplies
Copying documents
I can't set the setting for reducing/enlarging.
Aug 26, 2008 | Canon PIXMA MX310 All-In-One Printer
Reducing method interest calculation
Loan of Rs.50,000/- reducing interest to Government Employees for 2% p.a. for 36 Months
May 30, 2008 | Office Equipment & Supplies
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Feb 01, 2008 | Brother DCP 7010 Multifunction Laser...
Tablet gone insane.
I'm from ukraine, sorry my english;
Reason:
Random clicks hapens becouse moving tip not return to the front. It continue to sent chaotic pressure messages. Some times, when you start to lift pen, tip start to resilient and we have ugly dots again.
Here is solution:
May be auto silicon oil wil help by reducing rubbing. Or harder spring will help?
I use little bit of plasticine. I push it under the tip. It prevent tip from resilienting. I have no problems, since i made this.
Good luck.
Nov 05, 2007 | Genius Pensketch 9x12 USB Deep Blue...
Too dark
try printer driver settings, there should be a quality menu,
also there is a quality menu on printer menu
Sep 29, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Sharp AR-BC260 Color Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
