Question about Brother HL-2040 Laser Printer
COMPATIBLE TONER VS. OEM TONER
I HAVE AN OKI C3200N PRINTER THAT i USE TO PRINT IMAGES FOR ART WORK. I HAVE NEVER TRIED COMPATIBLE TONER CARTRIDGES , BUT HAVE ORDERED SOME FROM DATABAZAAR, AS OKI INK IS SO PRICEY. ANY ONES EXPERIENCE WITH COMPATIBLE TONER?
    President:
  • 627 Answers
Compatible toner is more cheaper than original, risking quality and due to low quality of the powder you can damage your printer.
I suggest to use original toner and at the printer properties set your printer to work in save toner mode.
Posted on Sep 30, 2009
Testimonial: "Although I was hoping that the answer would be in favor of compatible, I got confirmation of what I guessed it would be. prompt, and helpful... thanks"
How do i print borderless
you cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
Sep 17, 2014 | OKI C3200n Led Printer
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
The colors of my oki c5150 do not line up, they all print but the blue will start higher then the others making it look like a 3d picture without the glasses. It is not a set amount higher, even on the...
Sir,
This is the problem with toner cartridge. This may be clogged. Remove the toner cartridge, through cleaning and insert it. It may be solved.
Thanks Good Luck
Aug 24, 2009 | OKI C3200n Led Printer
OEM vs Compatible laser toners
It makes absolutely no difference to your printer settings if you go back to OEM cartridges. And yes its ok to mix the toners too.
Apr 04, 2009 | OKI Electric Industry C3520 Laser Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Oki Printer c3200 error code
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
May 05, 2008 | OKI C3200n Led Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Brother HL-2040 Laser Printer Logo
242 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
