Question about Gigabyte GA-8I945P-G Motherboard
Can Gigabyte GA-8I945PLGE-RH supports 4gb ram?
I have a Gigabyte GA-8I945PLGE-RH motherboard which supports up to 2Gb memory. Is there any ways to upgrade or force the motherboard to make it support 4Gb memory (2x2Gb ram)?
  • anthrox765
    anthrox765 Jan 22, 2012
    I checked - the BIOS sees 3.25 GB Max (2x2 GB).
    Regards,
    Anthroxhttp://thecompany.pl
  • Arash Ostadmohammadi
    Arash Ostadmohammadi Nov 10, 2017
    can it run 4 gb of kingston rams fsb 800 in dual channel mode?
    President:
  • 627 Answers
Sorry, but at the moment you can't do that. This is because the BIOS is programmed to manage only 2GB memory. I searched for BIOS upgrade to resolve the memory issue but with no luck. At the moment your motherboard supports only 2 GB RAM.
Posted on Sep 30, 2009
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
The ram slots on my ga-81865gm-775-rh-as MB are reporting my ram chips as 512k each rather than 1g each. The chips are 400mhz, supported, Kingston kvr400x643ak2/1g. I've already removed the ram and...
Hi, you can download a manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#manual
Your mainboard supports:
Type: Dual Channel DDR 400 / 333 / 266 support
  1. Max capacity: 2 GB
  2. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
Its maybe a setting in the bios or you missing a driver that causes the problem.
Or one of you ram modules is defect.
Sep 04, 2011 | Gigabyte GA-8I865GME-775-RH LGA 775/ 865G/...
I am buy ram 2gb bus 800 two pcs that was 4gb bus 800 in the two slot when I rest PC;show 3.xxx Total memory That most be Show 4.xxx . How I do?
This motherboard does support 4GB RAM, however, if you are running a 32bit OS, like XP, Vista 32 and Windows 7 32, you may only see 3.5GB as this is a limitation to 32bit. If you are running 64bit Vista or Windows 7 you will see the full 4GB.
Regards, Chris
May 13, 2011 | Gigabyte GA-945P-S3 Motherboard
I just bought a 2gb kingston memory pc2 5300 667 , my motherboard is Giga-Byte GA-VM900Mv.2 , it is written that , it should be compatible but when i put the ram inside , it just make blips that's all, do...
*********** supports,DDR2 667/533 up to 4GB Memory
Available with 2 DIMM slots supporting up to 4GB of DDR2 667 memory, GA-VM900M (Rev 2.0) provides the highest performance platform with the high-bandwidth (4.2GB/s) DDR2 memory solution.
You also check bellow the link for details.
http://www.gigabyte.com/products/product-page.aspx?pid=2407#ov
Regard's
Shibuda
Jan 03, 2011 | Gigabyte GA-VM900M Motherboard
No sound
Hi friends
follow the link and you can download go there support
http://drivers.softpedia.com/progDownload/GIGABYTE-GA-8I945PLGE-RH-Download-14162.html
or http://www.gigabyte.com/
Nov 29, 2010 | Gigabyte GA-VM900M Motherboard
HOW CANI GET UPGRADE OF GIGABYTE GA-VM900M REV. 2.0 TO SUPPORT OPERATING SYSTEM WINDOW 7
GIGABYTE GA-VM900M REV. 2.0 supports Vista so getting Windows 7 will be fine, Just make sure you have at least 2GB of RAM min- 4GB max DDR2 667 or 533 (2 x 2GB).
Clcik this link to check for yourself, please leave thumbs up if this helps you , thanks..
http://www.gigabyte.com/products/product-page.aspx?pid=2581#ov
Aug 27, 2010 | Gigabyte GA-VM900M Motherboard
Gigabyte GA-945P-S3
1. 4 DDR II DIMM memory slots (supports up to 4GB memory)
2. Supports 1.8V DDR II DIMM
2. Supports dual channel DDR II 667/533/400 DIMM
Jul 17, 2009 | Gigabyte GA-945P-S3 Motherboard
What to do with these MOBO driver files? GA-8I945PLGE-RH
download the lan drivers from here (see if the board matches)
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2156
Aug 22, 2008 | Computers & Internet
Gigabyte GA-8I945P-G Motherboard Logo
1,308 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
