Question about Apple Power Mac G5 Desktop
I have a G5 2.3 dual core running 10.4 I need to repair the system but have lost my install disc. Do you know where I can get one? Roderick Duncan
  • 22 Answers
To start up in Safe Mode, hold down the shift key and then startyour Mac. Safe Mode takes a while, so don’t be alarmed when you don’tsee the desktop right away. While you’re waiting, the operating systemis verifying the directory structure of your startup volume, andrepairing it, if necessary. It will also delete some of the startupcaches that may also be preventing your Mac from starting successfully.
Once the desktop appears, you can access and run disk utility http://macs.about.com/od/applications/ss/firstaid.htm tool just as you normally would. When First Aid is finished, restart your Mac normally.
Please note that not all applications and OS X features will workwhen you boot into Safe Mode. You should use this startup mode only fortroubleshooting and not for running day-to-day applications.
Boot Into Single User Mode Start up your Mac and immediately hold down the command key plus theletter ‘s’ key (command + s). Your Mac will start up in a specialenvironment that looks like an old-fashioned command line interface(because that’s exactly what it is).
At the command line prompt, type the following:
/sbin/fsck –fyPress return or enter after you type the above line. Fsck will startand display status messages about your startup disk. When it finallyfinishes (this can take a while), you will see one of two messages. Thefirst indicates that no problems were found.
** The volume xxxx appears to be OK.The second message indicates that problems were encountered and fsck attempted to correct the errors on your hard drive.
Posted on Oct 10, 2009
Can Drivers-Utilities reinstall disc be used to stop Endless Loop Start and Repair found root error Registry is Corrupted. Repair Action Registry Roll Back successful.
Doubtful... You'll need to use a OS Install disc to repair System/Registry files. If you have the System Install Disc, put it in your optical drive while your PC is already up and running. When the Auto-Run prompts, allow it to run, but rather than starting a fresh install, select the "Repair" option... It should then scan your system & settings and replace any missing or broken files. However, if your system can't start at all, place the OS Install disc into your optical drive while it has power then shut down your system. Wait 10 seconds and restart. Boot from the CD and then select the "Repair" option as mentioned.
Good Luck on fixing your system :-D
Apr 05, 2015 | Dell Computers & Internet
Am1201 amdathion 64x2 dual core processor 4400+
Try the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 30, 2012 | Computers & Internet
Dell wont open windows in start safe mode
You need to run the check disk utility. You have corrupt or missing boot or system files.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Dell Latitude D830 Intel Core 2 Duo T7250...
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
One Key Recovery is not working and can not find the hide original. All System - Recovery-Points also lost.Please help me!
Welcome to Fixya
Someone might have messed up your harddrive that is why one key recovery is already gone. Hidden harddrive partition will be erased if you installed new windows or repartiotion the harddrive. If you are going to restore the computer back to factory default state, you need to order the disc, If you still wanted to have the hidden partition back to your computer, you need to contact lenovo and send in the computer to repair department for HD re-imaging.
Thank you for using Fixya!
Apr 03, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My macbook when i uploading i turn off macbook and i turn on macbook didn't boot up just see turn around aound forever not go to windows i lost system disk unable to boot macbook
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
If the repair permissions finishes without any problems. You will have to reinstall the operating system.
Jan 05, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
Ethernet controller driver for acer aspire x1200 running vista
If you lost your installation disc, try to download this tool Driver Update Software and make your update. regards, Joe
Aug 21, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
Vga controller
btw these are your graphics hardware.
AGP 4X/8X or pci-e
Chipset Chipset Manufacturer document.write(neg_specification_newline('ATI')); ATI GPU document.write(neg_specification_newline('Radeon HD 2400PRO')); Radeon HD 2400PRO Stream Processors document.write(neg_specification_newline('40 Stream Processing Units')); 40 Stream Processing Units Memory Memory Size document.write(neg_specification_newline('256MB')); 256MB Memory Interface document.write(neg_specification_newline('64-bit')); 64-bit Memory Type document.write(neg_specification_newline('GDDR2')); GDDR2 3D API DirectX document.write(neg_specification_newline('DirectX 10')); DirectX 10 OpenGL document.write(neg_specification_newline('OpenGL 2.0')); OpenGL 2.0 Ports D-SUB document.write(neg_specification_newline('1')); 1 DVI document.write(neg_specification_newline('1')); 1 TV-Out document.write(neg_specification_newline('HDTV / S-Video Out')); HDTV / S-Video Out VIVO document.write(neg_specification_newline('No')); No General Tuner document.write(neg_specification_newline('None')); None RAMDAC document.write(neg_specification_newline('400 MHz')); 400 MHz Max Resolution document.write(neg_specification_newline('2560 x 1600')); 2560 x 1600 Cooler document.write(neg_specification_newline('With Fan')); With Fan Dual-Link DVI Supported document.write(neg_specification_newline('Yes')); Yes HDCP Ready document.write(neg_specification_newline('Yes')); Yes
Ok only 64 bit memory and 40 stream processors. Put your settings on 800x600 and all medium settings. Too bad, but you should also have 2 gigs of memmory to run the game really well.
I still get some lag every once in a while but I have 2 gigs of memory, 1950 pro and a dual core processor. You dont need dual core but at least a 3ghz single core.
let me know if this helps. send me an email if you have to as well and I dont mind helping you out in further detail with your system specs and what I think you could use to play some of the more current vid games.
May 26, 2008 | Gigabyte Computers & Internet
Dual Core
if the dual core was shut down when xp loaded (installed) it would crash when trying to run two cores.
Apr 30, 2008 | Toshiba Satellite A105-S4074 Notebook
Apple Power Mac G5 Desktop Logo
551 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
