Question about Health & Beauty
Freerider mayfair, no life at all in scooter
Freerider mayfair,reverse bleeper comes on as soon as charger connected,tried disconnecting it but still no life at all on scooter.have tried reset button!
  • Anonymous Mar 18, 2014
    the wig wag on my mayfair freerider has fell off how do you re connect it
    freerider mayfair how do you reconnect the wigwag
  • 1,263 Answers
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Posted on Oct 01, 2009
How to change the batteries on a freerider mayfair?
The batteries are located under the seat. you will need to remove seat and then the plastic cowl that covers the batteries and drive compartment.
Mar 28, 2015 | Health & Beauty
How do I get to the batteries on my mayfair freerider
Lift the seat off. remove seat mount by removing pin or screws. Lift plastic cover off carefully but mind cables going to lights. These can be unplugged. And there should be your batteries.
Oct 19, 2014 | Health & Beauty
I have mayfair freerider and every now & then it stops then goes again there are no green light flashes.
hi, does it just cut out ?, if so there is one fault that can cause that, worth checking, try pressing the lever in the upwards or downwards direction while going along, if it doesn't cut out , the throttle pot needs replacing ... it's worth also checking the battery and controller connections making sure they are a good fit and tight...
Other causes:
Battery voltage dropping too low...
Brake breaking down..
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Health & Beauty
Freerider mobility scooter
hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
Feb 02, 2014 | Health & Beauty
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Apr 17, 2011 | Universal Health & Beauty
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Scooter batteries will not charge. Green light on charger comes on briefly and fan tarts momentarily. Does green/yellow flash mean disconnection as indicated on the charger?
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Oct 01, 2009 | Shoprider Health & Beauty
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Jun 29, 2009 | Kitchen Appliances - Others
Health & Beauty Logo
498 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
