Question about Garden
Drive occasionally will not disengage
Drive won't disengage when the clutch is lever released,the problem is more prodominant when mower is under load (ie up hill), clutch cable is running free it seems to be in the transmission,not sure how the final drive engages but it may be worn and picking up under load,any thoughts,thanks
  • Doyley2 Sep 30, 2009
    This mower is a walk behind self propelled and has a shaft drive from the engine to the gearbox. It drives fine, something in the transmission won't release to disengage drive.
  • 437 Answers
If it has a drive belt, you may think about replacing it. It may be stretched out to the point it is not gripping like it was when it was new.
Posted on Sep 30, 2009
Release blade engagement attachment lever craftsman #917259330
there sure be a lever to disengage on the fir =e wall of the lawn mower deck or near fire wall o the lawn mower
Oct 16, 2014 | Garden
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
Blades not disengaging
is the blade engagement system a lever or a switch?
If a lever , then look on the deck where the pulley applies tension to the drive belt for a sticking point. the cable from the lever will be attached to it and it should move smoothly in and out of drive position. sounds like the pulley is not retracting when cable is released. check for sticking of pulley arm or maybe a missing return to idle/off spring is broken or missing.
The deck should disengage as soon as the tension on the cable is removed.
if electric, the clutch itself is always getting power, so a swithc circuit fault is to be expected.
Jul 21, 2013 | Husqvarna 23 Hp 48" Deck Yard Tractor
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Riding mower won't go nowhere it's got drive belt on but won't drive
Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
Oct 03, 2012 | Craftsman Garden
NEED TO DISABLE PTO SAFETY SYSTEM ON CADET RZT
just bypass the safety switch or hard wire from switch to the clutch
Apr 30, 2012 | Garden
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
