Question about Minolta CF2001 Copier
Code cof37 copier make a few copies then code cof37
  • 146 Answers
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Posted on Jan 04, 2008
ERROR F5-02 call for service code AR 235 MODEL
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Jan 15, 2011 | Sharp AR-235 Copier
Colored lines are printing on the printed copies. It does not occur when we copy items, only when they are printed. The maintenance code "AA" is on the screen as well. I don't know what that code means....
When this happens, you need to clean the scanning area. When you lift the top cover, you will see a green clip on the right hand side (of the actual cover) and you clean the scanning section on the left hand side on both the bottom of the cover and on the base where you would put your original copies.
Then open where you put the toners in, and pull out on the green rods a few times each, and this will help clear the grid.
May 20, 2010 | Sharp MX-2300N Color Copier
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Error code C400
that code points to your laser unit. you will have to have a tech install a new or refurbished one. then code will clear.
hth,
razoras
May 28, 2009 | Copystar CS-2030 Copier
How do ya reset fuser code (H-4) Xc1044 Xerox?
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
The 391 code problem
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Sep 01, 2008 | Ricoh Aficio 450 Copier
COF37 error code
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Jan 20, 2008 | Minolta CF2001 Copier
Minolta cf 2001
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 18, 2007 | Minolta CF2001 Copier
Fault Code COF37
COF37 is a code for ATDC high black density failure. Several different things can cause this code & I assume it does not clear by turning the machine on & off.It may be a dirty sensor or may need a black developer change. Either way I would recommend contacting a tech as the process unit can be tricky to remove.
May 28, 2007 | Minolta CF2001 Copier
305 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
