Question about Tefal AquaSpeed FV5155003 Iron
I have the problem of water leakage for my iron
  • Tefal Master
  • 43,501 Answers
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Water is running out the base of the iron
Your iron is defective. Leakage is a common failure.
Dec 21, 2017 | Irons
Tip
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
Owners manual
Things to try:
1. Fill iron with tap water ... distilled water may cause leakage.
1a. If you have very hard water, dilute with 50% distilled.
2. Fill the iron while upright, then allow to fully heat before using.
3. Use higher steam setting ... lower settings can cause leakage.
4. Allow your iron to "recover" (i.e. build up steam) if you have a spray or "steam burst" button. Trying to use it too rapidly can cause leakage.
Be sure to clean your iron according to your manufacturer's directions. Chances are, that means using a vinegar-water solution to break up any mineral deposits. You can find a helpful video, here: http://laundry.about.com/od/productreviews/qt/vincleaniron.htm
SAFETY FIRST. Try not to work on a hot iron, or one that is plugged in to a power outlet. Water and electricity do not play well together.
Dec 29, 2012 | Bosch Irons
Iron producing lots of water
heatman101
May 18, 2010 | Philips GC 8220 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Shark Euro Pro Iron turns of while ironing
what makes the water spit out of the iron and make my clothes wet
May 05, 2008 | Euro-Pro Shark GI490 Iron
Tefal AquaSpeed FV5155003 Iron Logo
712 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
