Home | Routers | NO INTERNET CONNECTION
Routers
Problem for Routers
Generic problem for all Routers
By nastynancy on Dec 19, 2007
WE ARE NOT ABLE TO GET ANY INTERNET CONNECTION IT IS SAYING LOMITED OR NO CONNECTIVITY.BUT YET PLUGGING A COMPUTER DIRECTLY INTO ROUTER YOU GET CONNECTION
Same Problem
May 16, 2009
-   I have also run into this problem in the past wee. The cable connection works perfectly well when directly plugged into my PC, but when I try to plug it in through the Linksys wireless-G Broadband Router (and from there to the PC), I lose all internet connectivity and can't seem to restore it.
I seem to have found a lot of people on here claiming the same problem, but no solutions.. Is this fixable?
-   Dmortensen2
May 01, 2009
-   I have a belkin 54g router & my Dell laptop (running Vista) connects to the router but the router will not connect to the internet, if i plug the laptop directly into the modem the internet works fine though. Why won't the router connect to the internet? -   Guest
Mar 15, 2009
-   i clicked on something in firewall and now my ipadress and everythin has changed the laptop wont connect to are internet no more neither will my ps3 but i can still connect to on here and when i try put default ip adress in like 192.168.2.1 it just says it not there. -   Guest
Mar 03, 2009
-   I just reformatted my Windows XP. Even though I plugged my internet cable into my router, I still get no internet access. After going to the control panel to set up networks, and completed all the wizards, it still didn't work. I tried changing the settings, trying all the options, but it still didn't work. My computer doesn't even show the two computers with a globe or X on it! Just a plain audio speakers, and a shield for security, as well as the time. Anyone find a solution about all this? -   pinkgirl127
Mar 02, 2009
-   recently my computer was "attacked" with many problems most likely due to a virus i eventually got al the problems (i.e. sound card missing etx.) but my laptop still can't move if i want internet connection-- i have to keep it pluggedinto the router. Please Help my homework's never gunna get done while watching tv ever again if i dont get a soulution! -   emmabean2
Best Solution
posted on Feb 07, 2008
Helpful)
haltech
Rank: Wiz
Rating: 89%, 51 votes
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
trying to play xbox live with 2 xbox's and wont let us connect but without it, it lets us connect... (More)
Answer
my motorola router is unidentifying my username and password. How do I reset my Username and... (More)
Answer
rf router to rf router setup i need to have my maxG router jump to my d-link router that has the... (More)
Answer
wired, router, modem and internet light comes on but i am not allowed to browse...why is that? if i... (More)
29 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 05, 2009
Router is giving a low signal output,,, how do i correct., has worked perfect for a 2mo period,, now,,it wont hardly connect to internet.
Comment by tinathellama, posted on Jan 26, 2009
I have internet through the modem but no wireless. The lights are on the router, WRT54G. I've tried reinstalling, shutting down, restarting and checking the encryption key. My router is listed for the for the wireless networks in the area. When I try and connect wirelessly I'm getting the message that there is no internet connection detected. My router stopped working exactly 1 year after I installed it.
Comment by brandynicole, posted on Jan 15, 2009
i have internet when plugged in to modem but when plugged into the belkin router there is no internet connection
Comment by dickrichie, posted on Jan 06, 2009
just reformatted with xp -- says network connection is excellent but won't connect to internet -- can't find server -- any suggestions?
just reformatted my computer with windows xp -- connects to modem and wireless router says excellent connection but will not open any wages or connect to internet at all -- says can't find server -- any suggestions??
Comment by Guest, posted on Oct 24, 2008
I have the same problem... whenever I turn on my computer though, running the EZSetup Wizard helps me for that session. Halfway through the setup, I get an error message and cant continue, but I'm magically connected to the internet. Once I shut off my computer again, bye bye internet connection. Wireless connection to the router itself is no problem. Wired connection to the router still gives me no internet (until I go through the EZSetup). Odd.
Comment by damojo, posted on Oct 19, 2008
NO internet
Able to ping to modem
Comment by faxson, posted on Sep 12, 2008
My computer recognises the wireless signal as excellent. But fails to get on internet.
Comment by tinyburcia, posted on Aug 23, 2008
can't connect to the internet using a network cable
can connect wirelessly
packets received..0
able to ping IP
Comment by Guest, posted on Aug 20, 2008
i have internet when it is hooked right into the modem but when i hook up my router i cant even get online
i internet
Comment by tomfra, posted on Jul 28, 2008
pc works when internet is plugged right into it, but not when hooked up thru router
Comment by grant-y, posted on May 26, 2008
have versa link 327w. Have a hardwired desktop (hosting) and 2 desktops and a laptop receiving. one of the desktops and the laptop work. the 2nd desktop doesn't get signal (limited connection etc). Have tried repairing, manual IP config, both microsoft fixes (winsock and guided help for tcp/ip). Have reset the router (unplugged everything, waited, plugged back in). Anything else I can try?
Comment by billybullse, posted on May 18, 2008
We lost internet last week, the provider lost signal.
The signal has come back. We can connect to the internet when plugging staight into the back of router.
Whe using the wireless router we cannot get the internet.
Can you help.
Comment by flash39507, posted on May 10, 2008
I have a AOI-891 Router that is in-line and working with cableone broaband,, I am changing to DSL and the rounter is not working with ATT, now I dont have any of the books that came with it,, someone has not put them in the right place,,, from What I understand the rounter will not let me sign in with ID and pass word,, what is the defult Id,, so I dont have to re-set up my workstations
Comment by nuselak, posted on May 08, 2008
Cannot force my new Belkin G Router F5D7230-4 to connect to my Sympatico.ca server. My PC is OK, my laptop is connected wirelessly to the router, but despite setting all parameters manually on the laptop as are on the PC, no connection.
Comment by Guest, posted on May 06, 2008
No internet connection,plug into the computers but have I have windows VISTA is that the problem ???
Comment by kitnkaboo, posted on Apr 09, 2008
i cant get my router to connect to the internet. I had no trouble until i tried to hook directly into my laptop and unhooked the cable from the modem. I have to run a wire directly to the modem can you tell me what I can do to fix this problem? Thanks
Comment by nataliel, posted on Mar 27, 2008
This is my 2nd router, the other belkin died. Have just installed a new anti virus on my computer but have had no problems for 24hrs. Now all of a sudden can no longer access the internet thru my router. i have to plug into my computer from the modem?????
HELP
Comment by Guest, posted on Mar 17, 2008
dont work at all
Comment by yakmal, posted on Mar 15, 2008
My wirelss router was working fine and I had no problem using the internet from my wireless laptop. However, a couple days ago I suddenly could not get internet access and no my laptop network connection says local access only. I can get internet by directly connecting my laptop to the router but that's it. Any ideas.
Comment by QsbutnoAs, posted on Feb 19, 2008
i have just recently bought a laptop and need wireless internet connection to my computer through the belkin router.......
i am hopeless and was wondering if anyone would know how this needs to be done and what steps need to be taken???
Comment by Guest, posted on Feb 11, 2008
i have problem to configure 3com officeconnect adsl wireless 54mbps 11g firewall router using bsnl broadband
Comment by suezay, posted on Feb 11, 2008
can you explain how to do this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1347
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
