Question about Tally T2250 Matrix Printer
How to share tally
I've 2 systems. i want to use tally installed in one system. can i use one company of tally in one system and another company on another system on networking. can the data is used in 2 system simultaneously. and how this achieve.please explain
    Master:
    Sergeant:
  • 460 Answers
First you installed the printer in one PC & share it.now you can go another PC & go to start>run>\\ IP address of the PC which printer is installed>enter
now you will find the printer.now right click of this printer icon & then click to connect.now your printer will be connect with both Pc's.
Posted on Sep 30, 2009
  • prashant garg
    prashant garg Sep 30, 2009
  • prashant garg
2 Suggested Answers
SOURCE: Tally Data Recover
Here is a solution for your problem, simply use the inbuilt tally recovery tool as described here - http://www.megaleecher.net/Tally_Software
Posted on Jul 12, 2008
Tally error code 407,system error code 11001
Just take sharing from another computer tally folder and run it hope fully nothing will happen
Thank you
Harsha
May 10, 2016 | Computers & Internet
Error in tally 7.2
What Operating System are using?
A safe solution would be to go to your Control Panel, from the Start Menu. From there, go to "Add/Remove Programs", and find your software application. See if there is a "repair" option next to it, and if so, run that.
Unless you have the original discs and product key for this software, please don't uninstall it - it will be difficult to get it back.
If this does not help, or you don't see a "repair" option, please post back with more information.
Apr 10, 2008 | Computers & Internet
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to support@tallysolutions.com .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//www.tally9.info
http//www.tallyerp9.com
I found this howto here: https//answers.yahoo.com/question/index?qid=20100521043632AAsKkQs
Mar 31, 2014 | Computers & Internet
Tally erp 9 working slow
you have not mentioned the networking involved .?
how are the clients networked to the server ?
Are you using a switch or a hub ?
Are you using a fast ethernet connection 100 Mbs or 1000 mbs into server from a network switch ?
How fast ? 10 mbs will cause problem on five client machines sharing 10 mbs into a server
Jul 07, 2017 | Microsoft Windows 7 Home Premium 64BIT...
Tally ERP 9 is not responding
Uninstall Tally, cleanup drive (using disk cleanup option), intall fresh one tally.erp 9 rel 2.0
open tally, rewrite data pressing ctrl+alt+r > select company, done
for tally products & Customization visit www.tallyplus.in
Feb 08, 2013 | Computers & Internet
I have installed Tally 9 in my laptop. The operating system is Windows 7. Now when I try ti create a Company, it gives error massage " Exiting Tally ! Error in TDL. Part:Basic Company, Insufficient...
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
May 02, 2011 | Computers & Internet
I am unable to create a company after installing tally 9 v 2.14 on my system. On clicking create company option in gateway there is an error message sayin\r\n " Exiting Tally! Error in TDR. 'Part:Basic...
I am unable to create a company after installing tally 9 v 2.14 on my system. On clicking create company option in gateway there is an error message sayin\r\n " Exiting Tally! Error in TDR. 'Part:Basic Company' Insufficient Height to Allocate" please help
Sep 28, 2010 | Google Computers & Internet
I am not able to open the file in tally 7.2
Follow the below steps.
1) Please verify datafile Path.
2) Open Tally and press CTRL + ALT + R to rewrite company.
Mar 03, 2010 | Computers & Internet
Tally9's features
Tally uses the latest technology to provide features in a simplified manner. It is a robust system that is easy to use.
Multilingual Business Accounting and Inventory Management Features
  • Multilingual Support: Tally can now be used concurrently in the language of your choice. Tally's interface is now available in Bahasa Melayu besides English and the Indic languages Hindi, Kannada, Bengali, Gujarati, Marathi, Tamil, Punjabi, Telugu, Malayalam and Hinglish (colloquial)
  • Payroll: Payroll in Tally enables users to set up and implement simple to complex salary structures. You can align and automate payroll processes and directly integrate them with main stream accounting applications. Tally Payroll also supports configurable formats for payslip printing; flexible salary/wage, attendance, leave and overtime registers; gratuity and expat reports
  • FBT (Fringe benefit tax): FBT in Tally is a one time, easy to enable configuration. It supports Challan management and printing for prompt and accurate filing of tax. On entering the transactions, Tally automatically calculates the FBT and generates the reports
  • VAT Composition Returns: VAT Composition Returns in Tally provides fast and error-free voucher entry with complete tracking of each transaction. It supports the printing of VAT Composition Returns of any state in which VAT has been implemented. The Composition Rate of VAT is automatically recognised based upon turnover and the tax payable is calculated automatically and shown in the Return Form
  • Excise for Dealers: Excise for Dealers in Tally generates Excise Invoices for Traders, Tracks Purchase Invoices during sales and duty credit availed and passed on. It also maintains the Excise Stock Register and generates Quarterly Returns
  • TDS (Tax Deducted at Source): Tally allows you to configure TDS ledgers by specifying the Nature of Payment and Assessee Types, along with the Rate of TDS. It determines user-defined expense/payment types with user-defined rates. TDS can be deducted automatically based on pre-defined rates, once the transactions exceed the threshold limit. You can generate Challans, the Form-16A Certificate as well as the quarterly and annual returns. Tally also generates e-TDS files in NSDL compatible formats
  • Synchronization: Synchronization in Tally helps you transfer data between two or more locations (Example: When a Branch Office and the Head Office of a company reside in two different locations). Synchronization can be done, both ways (For Example: You can transfer the data from Branch Office to Head Office or vice-versa).
  • E-mail reports and documents directly from Tally
  • Publish reports in HTML on Web or Intranet and share them with suppliers, customers or your own staff
  • Direct web browsing capability from within Tally that avoids switching between programs
  • Exchange data with other systems using XML. Tally gives you the means to collaborate with others and share information like never before
  • ODBC connectivity opens up Tally. This makes Tally fields in ODBC to be compliant with programs like MS Word and MS Excel. This enables you to integrate Tally data dynamically into other ODBC systems. It even designs a form like remittance advice and imbed fields like Customer name and address, account balances and so on, in Excel/word
Jul 11, 2009 | Tally Intelliprint ML450 Laser Printer
Tally 5.4 Error
If it is a data corruption try this: 1. exit all companies in Tally 2. Press Ctrl + Alt + R 3. Select the Company that has a problem...
If this doesnt fix it they try uninstalling the program and reinstalling it.
Jun 30, 2009 | Microsoft Windows XP Professional
Tally T2250 Matrix Printer Logo
198 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
