(1) Loosen screw on negative ( - ) terminal clamp, lift negative cable off terminal, and put cable end somewhere where it can't touch the battery. This stops the positive terminal from being "live" with respect to the rest of the car.
(2) Lift plastic cover from positive ( + ) terminal. Loosen screw on positive terminal clamp, while making sure your screwdriver is nowhere near the negative terminal at all times. Lift positive cable off terminal, and put cable end somewhere where it can't touch the battery.
(3) Loosen the butterfly nuts over the clamp that holds the battery to the tray. One butterfly nut will have to come off completely, the other can stay on so you don't lose the clamp down the middle of the engine. Swing the clamp off to one side.
(4) Lift the battery out of the tray, keeping it upright at all times.
To reinstall the battery, follow the above steps in reverse order.
