Question about Kenwood KSC-310CCS Center Channel Speaker Car Speaker
Kenwood car stereo KDC-W3534 : warning message PROTECT
Hi there!
My Kenwood stereo KDC-W3534 now just reads 'PROTECT' constantly when switched on and i don't have the handbook anymore..
Any ideas would be greatly appreciated!
Thanks.
  • 1 more comment
  • meghalped Aug 24, 2008
    power on but it show protect what that mean no aor even cd not playing it show protect all time
  • shine on Oct 08, 2008
    i iam having the same proplem and i just bought my cd player ?? any help please
  • Anonymous Jan 09, 2009
    my kenwod radio says protect when turned on
I had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Posted on Aug 28, 2008
  • kevin kaplan
    kevin kaplan Mar 26, 2016
    Under the faceplate there is a little reset button u push with a pin just push it it will reset the headunit
I've just had the same problem and looking at the above suggestions took the head unit out and what do you know, half of the two part earth wire in my car leading to a crimped joiner had come loose where the headunit had been pushed too far back in the cage by my wife. No big deal, just undo join, put wire back in, tape up with electrical tape and ta-da! Fully functioning head unit again.
Posted on Sep 12, 2010
Well its so easy just unplug the earth wire and it will work fine so no more 'PROTECT' good luck ....for any comment just ask
Posted on Nov 17, 2008
    New Friend:
Reset button did it for me!:):):) by the way, reset button is behind the removal face-plate
Posted on Mar 17, 2013
No need to do any silly thing, just press the RESET button located on the front panel. And there you go, its don't!
Posted on Sep 08, 2012
The speaker has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated so try to wire or insulate the speaker cable properly and press the reset button.
Posted on Aug 16, 2010
  • 78 Answers
This is a safety feature and it usually suggest that there is a problem with the internal amplifier, it could also be a trapped speaker wire. Remove the radio and check if any of the cables have been damaged and if you power up the radio with the speaker plug disconnected that will tell you if the fault is in the car or the radio
Posted on Dec 23, 2007
 i disconnect the batteries and reconnected  it and everything worked  fine for a while then again the message is back PROTECT
Posted on Oct 08, 2008
  • shine on Oct 10, 2008
    I found the  answer to this problem just take unplug the earth wire and it will work fine i tried it and its ok now 100/100
4 Suggested Answers
  • 147 Answers
SOURCE: Kenwood kdc-148 is in protect
A car audio component like an amplifier (or in this case a headunit) is most likely to go into protection mode when there is a short in one of the speaker outputs-- in other words, if the + and - ends of one of the speaker leads are touching, this can cause damage to the internal amplifier of the unit. Some units will respond by putting the amplifier into "protection" mode, so that it does not damage itself. Check connections on the back of your unit, or take it back to the shop that installed it.
Posted on Mar 04, 2011
SOURCE: I a kenwood KDC-3037
i have a kenwood kdc S3009. All I need to know is how to set the current time
Posted on Sep 22, 2010
  • 78 Answers
SOURCE: Kenwood KDC 237SA
You need to switch the aux function back on and to do this you need to turn the radio on to standby and press and hold the menu button for a few seconds and then use the toggle switch on the right side of the fascia to get to aux and then flick the switch forward to switch the aux on
How do i tume a kenwood kdc-w3534
You may download a copy of the manual here.
Feb 25, 2013 | Kenwood KDC-W3534A CD Player
Kenwwod KDC MP 543u Protect mode problem
This indicates a short in one of the speakers, or possibly the speakers are not wired correctly. Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when .
Correct wiring for 95 Corolla is as follows:
1995 Toyota Corolla Wiring harness, Kenwood wire color
Radio Constant 12V+ Wire: Blue/Yellow, yellow
Radio Switched 12V+ Wire: Gray, red
Radio Ground Wire: Brown, black
Radio Illumination Wire: Green, not used by Kenwood--please tape off
Radio Antenna Trigger Wire: Black/Red, blue
Left Front Speaker Wire (+): Pink, white
Left Front Speaker Wire (-): Purple, white/black
Right Front Speaker Wire (+): Light Green, gray
Right Front Speaker Wire (-): Blue, gray/black
Left Rear Speaker Wire (+): Black, green
Left Rear Speaker Wire (-): Yellow, green/black
Right Rear Speaker Wire (+): Red, purple
Right Rear Speaker Wire (-): White , purple/black
Dec 29, 2011 | Kenwood Car Audio & Video
Need an instruction manual for a Kenwood KDC-W3534 car audio
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 10, 2010 | Kenwood KDC-W3534A CD Player
I get a message Protect. All other controls are
Usually the protect is a safe mode to indicate that your set is unsafe. Starrt by checking the speakers, speaker wires for shorting. detach the speaker lines and power on the set for confrimation. check in power/auxially circuits in the set. it is possible that your mechanism drive / audio output drive Ic's could have shorted. Most of these cirrcuits have an error detection of higher current to cut off power and issue a protect warning. so discoonect the IC power to confirm. Hope this helps. Good day
Jul 12, 2010 | Kenwood KDC-MP435U CD Player
I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Jun 24, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Kenwood KDC - MP 235
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Dec 08, 2008 | iLO XM-MP3-CD Car Stereo
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
10,401 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
