Question about Vivitar ViviCam 5385 Digital Camera
How can i view my pics, when its parameter is incorrect?
CANNOT OPEN QUICKBOOKS
According to intuit Error : 80070057 PARAMETER INCORRECT is most common problem. for knowing its cause and step wise solution follow Error 80070057 the parameter is incorrect or You do not have sufficient... and if need any guidance while understanding any technical prospect follow Intuit Help by Intuit Certified Technician .
Jan 22, 2014 | Intuit QuickBooks Pro 2009 Full Version...
Ipad PNG pictures can't copy to harddrive - parameter is incorrect
you can try using the app "Shareit". it will give you an option to transfer files from ipad to computer.
Sep 05, 2017 | Tablets & eReaders
Installing yahoo messenger incorrect command line parameters
why cant i send a message to all my friends on yahoo messenger?how can i solve this?
Jul 02, 2009 | Yahoo Messenger
Cannot open or copy - parameter is incorrect?
Are you using the same card reader for both memory cards? It's probably just your card reader. I had this problem before and it turned out to be my usb cable for my psp.
Mar 15, 2009 | Sony PlayStation Portable (PSP) Console
The parameter is incorrect
download a software called mini tone and it will read it
Feb 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Cannot Copy {filename}: Parameters are incorrect
First suggestion: Make sure the battery in the camera is completely charged and try again.
Your best bet is to use the card reader when it arrives. Sounds like a corrupt file on the memory card. Be sure to completely format the card (not just erase pictures) after you successfully get the images off. And I suggest running through a complete set (full card) of images that you don't care about (shoot your backyard) before you trust that memory card again.
Memory cards are (relatively) cheap, so consider replacing the card soon.
Dec 17, 2007 | Nikon D70s Digital Camera
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Oct 17, 2007 | Vivitar ViviCam 5385 Digital Camera
Cant retrieve pictures
I cant get my camera to download pic into computer..
Oct 14, 2007 | Cameras
Accessing pics from memory stick
This is a computer error. Check images are there in the camera by looking at the review screen. Then check you have not 'locked' the stick or 'protected' images turn off the protected then try
Aug 14, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
24 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
