Question about Sony VAIO TR1MP Notebook
Unable to detect Hard drive on Sony VAIO model VGN-NR110E. While installing XP it gives error that no hard drives. But in BIOS it is showing HDD 120 GB. Pls help. waheed
  • Abdul Waheed Khan Sep 30, 2009
    I have checked these things are OK
    unable to install windows
  • 10,515 Answers
Let's check the easy things first.
Does the drive have power?
Does it spin up?
Is it set as Master, Slave or Cable Select?
How is it connected to the motherboard?
If by ribbon cable, 40 or 80 conductor?
If by ribbon cable, which connector is the drive plugged into? Middle or End.
Start there. Then get back and we'll move forward.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 30, 2009
  • taran_2005
    taran_2005 Sep 30, 2009
    Thanks for your response!!
    Check the below mentioned checklist :-
    1. Ensure that the SATA HDD (hard disk drive) is installed, detected,
      and listed in the BIOS SATA hard disk list. When a SATA hard disk is
      connected to SATA connector, it should be detected at least at hardware
      BIOS level. If any connected SATA HDD is not listed in the S-ATA drive
      list, check the SATA cables are properly connected to the
      connectors/ports, and that the SATA cable is in the master slot on the
      motherboard.
    2. Some SATA chipset especially older version such as those from
      Silicon Image 3112/3132 and etc. requires driver for the OS setup to
      recognize the SATA drive. Make sure you have a copy of driver from the
      manufacturer ready. To Install Windows XP, the driver must be in floppy disk. Press F6 to load this third party driver when prompted in Windows XP/Vista.
    3. SATA-RAID feature will most likely require additional driver for OS
      to recognize the hard disk in RAID array, as OS especially Windows does
      not have a native SATA RAID driver. Again, for XP, the driver must be
      resided on a floppy disk, and press F6 to load/addl additional driver
      for SATA-RAID drive during Windows setup.
    4. For those without SATA/RAID driver, it’s also possible to disable
      SATA RAID option in the BIOS. OS normally has native SATA driver
      (except old on as specified above), and thus able to detect the SATA
      disks.
    5. AHCI mode on SATA hard drive also requires appropriate drivers in Windows XP/Vista. Disable AHCI or change SATA MODE to IDE emulation mode in BIOS so that SATA hard drive will work as just a normal hard drive utilizing native SATA driver in Windows or other OS.
    If all the above check points are confirmed, then either there is an issue with the Hard Disk installed or any of the connections. You need to call tech to investigate the same.
    Hope i helped you.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sata enable/disable is not appearing under advanced setting in the BIOS, that makes blue screen shows up during installation of windows xp
1. Turn Off the computer
2. Try taking out the hard drive and put it back in
3. Go to the BIOS again... see if the BIOS detected the hard drive otherwise
4. Replace the hard drive
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
Win XP doesn't "see" hard drive, can't install
If it is in a loop, and does not recognize the hard drive, the hard drive may have some corruption or failed sectors on it, or dead all together. To test if its dead, hit either ESC, F2 or F12 on your keyboard on the vaio screen, should launch the BIOS where you can see what storage devices it detects. If there is no hard drive it is either dead or lost connection. If it does show up there you can test for sector corruption by downloading HDD regenerator (google search) and running the scan. It will give a drive map if there is any sector damage (not mechanical failure) Any questions, let me know.
May 13, 2011 | Sony Vaio VGN-NR110E/S Notebook
How to remove hard drive from Sony Vaio Laptop VGN - NR110E?
On the bottom of the laptop there should be a cover for a quare or rectangle shaped slot, most likely with two screws in it. Unscrew these, and the hard drive bay will come loose. Just unscrew it from the bay and it should be free.
May 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
I have a sony vaio vgn-fj78gp. i have to replace hdd 400gb sata, when i install the xp operating system igot an error
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 14, 2011 | Sony VAIO VGNFJ Series VGNFJ78GPB...
I FORMATTED MY HARD DRIVE AND TRY TO PUT MY VISTA BACK ON AND IT IT TELLING ME CANNOT FIND HDD.HOW CAN I GET THE WINDOWS TO RECGONIZE MY HDD
check BIOS, if ur HDD is listed in boot seq, pheriferals etc
if u want to make it factory fit
follow instruction in my website FormatDisk page
www.sureshayyar.110mb.com
Jan 20, 2010 | Sony Vaio VGN-NR110E/S Notebook
I have a Sony Vaio VGN-Nr110E and the right mouse button will not depress. Also, I am tired of windows Vista, but whenever I go to downgrade to XP it will not let me... kind of a double wammy question...
Click Start
Click Control Panel
Click Mouse
Check to see if the RIGHT button is enabled and mapped to a function.
If your computer is "designed for Vista", your experience with installing XP will be unsatisfactory -- drivers for audio/video/networking will be unavailable.
Anyway, backup your files to an external hard-drive.
insert the Windows XP CD, and "cancel" any "auto-run" things.
Shutdown.
Restart, and force the computer to boot from the CD.
As it boots, you will be able to install XP, no matter what is currently on the hard-drive.
Nov 01, 2009 | Sony Vaio VGN-NR110E/S Notebook
Sony vaio does not recognixe new hard drive
what was the os earlier is it a xp ? ..... check it on the BIOS whether hard drive is detecting or not
Sep 08, 2009 | Computers & Internet
I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Jul 21, 2009 | Sony VAIO VGN-NR160ET Notebook
Sony VAIO TR1MP Notebook Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
