When i turn my freeview on the screen says epty and i cant get a signal any ideas
How to turn on curtis freeview box without remote my dog chewed
reset the code go to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 01, 2012 | Televison & Video
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Slanted screen on freeview connection to Beko 28426DNS,
your television has a defect.the best remedy for this is to resolder the jungle ic. the technician can do this job.
Jun 19, 2010 | Televison & Video
I cant get my durabrand freeview box to work.
i have pluged in all the plugs to be in and all in the right places but i have no sound but im getting a picture ??????
Nov 22, 2009 | Televison & Video
We need freeview help
Just because your'e in a Freeview area doesnt necessarily mean you can recieve Freeview signals successfully without having to make other changes.
The most common other change you need to make is to install a different or higher performance aerial, or it needs to be re-located somewhere where it can get a better "view" of the transmitter, e.g. if it is currently mounted in the loft space then this may well give a good enough signal for the old analogue TV but wont be good enough for digital. It will need to be relocated outside, as high up as possible, and accurately pointed towards the transmitter.
Unfortunately without being able to examine your particular installation, it's impossible to say whether your current aerial is good enough for digital, but hopefully this gives you some ideas where to start, and if nothing else, help you discuss your problems if you engage the services of an aerial/TV engineer.
If your aerial is
Nov 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Cant get the dmtech lq17xts tv's freeview to work
General reset procedure for DM tech is:
1. Have Analogue station showing,
2. Press display button on remote,
3. With display info panel in view on screen, press 1 1 Line buttons on remote, this should bring up reset menu on left hand side of screen.
4. use up/down arrow buttons on remote to select either Reset or EEPROM then use right arrow button on remote to select the appropriate procedure
NB - on my set, selecting OFF the annoying melody that plays when the TV is turned ON/OFF diasbles Digital TV (Freeview). Turning ON the annoying melody makes DigiTV work again!
Jun 24, 2009 | Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
Toshiba 37X3030D LCD TV
no, the tv has a setting that auto changes the screen ratio. you can turn the auto screen ratio off in the settings section. Once you have turned it off put ratio to 16:9 and it will solve the problem.
Jun 17, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
