Question about Boating
Computer is gone bad on boat 4.3 v6 trying to find out how much for a computer and where it is located? Also how hard it is to install?
  • 5,546 Answers
There are some boat Salvage yards which carry used parts. Some of them will ship the parts. You can do an internet search on the Browser and find both new aftermarket parts and more used parts.
You need to give the make of the outdrive and year model for what you have. You also need to indicate if you are talking a motor module or a shift module. Some computers are universal and others are specific to your information.
Most of the time the engine module is bo;lted on the motor close to the coil paks. The shift modules are bolted to the manifolds with wires going to the micro switches.
Posted on Sep 30, 2009
Marin shop has installled 5 starter solenoid and they all gone bad. 60 hp mercury 4 stroke. Why do they all go bad.
Try using on off a larger motor.(heavier duty).. or are they using aftermarket parts (sometimes inferior)
Apr 20, 2017 | Mercury Boating
Where are the engine codes located on a 1970 Pacemaker 45' boat. Where are Boat Identification codes located on pre 1972 boats? Specifically this Pacemaker?
With a boat 44 years old, your boat engines may have been replaced or at minimum, overhauled. You might resubmit your question with some easy information you can add:
Gasoline or diesel engines?
Many were Crusader engines & you can usually see the name like this on the top portion of your engines.
You can see what color the valve covers are (blue, black, etc.).
You can see if they are V-8 engines if they have two long valve covers on top.
Most engines have a name plate on them (yours may be gone if original engines). Any mechanic you run into might find it quickly or recognize the engines.
Enjoy your boating. Pete
Apr 04, 2014 | Boating
When I plug in my flash drive, my computer won't read it. The light on the flash drive does not light up. Is there any way I can fix this?
Try it on another computer. If it works, then your computer's USB port has problem. Check the ports and make sure they are properly connected and are cleaned. Also make sure the USB driver is updated/installed. You can also try it on another USB Port of your computer. If it doesn't work on another computer, then I would say your Flashdrive is bad or gone.
Let me know if you need further help.
If you find this helpful, please take few seconds to rate the solution by hitting the 4 thumbs. If you can spare few minutes, you can even leave a testimonial to express your feelings about the solution.
Good Luck.
Thanks for using FixYa.
Feb 15, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Crankshaft sensor is going bad how do i access it top change it
Which engine is it? 2.7 Lit V6? 2.4 I4 - 4 cylinder? or the 3.5 V6? Each one is different.
1. 2.4 I4, 4 cylinder - located at the front of the engine at the crankshaft (behind timing belt cover)
2. 2.7 Lit V6 - Near transmission on the left hand side in the engine block behind the right edge of the exhaust manifold
3. 3.5 lit V6 - located at the front of the engine at the crankshaft (behind timing belt cover)
Feb 07, 2011 | 2004 Hyundai Santa Fe
Starter out in my 2002 dodge stratus where is it locat
If its a 4 cyl, its right below the computer on the driver side when you open the hood. Just behind the radiator. It attaches to the transmission bellhousing. On a V6, not sure but probably close to 4 cyl location. Not too bad to replace on a 4.
Oct 21, 2010 | 2002 Dodge Stratus
Hi there, seem to have lost my external harddrive on my desk top, and it is making a beeping sound??
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
Nov 12, 2009 | Maxtor Hard Drive
Bad key switch on 1975 merc. 1150 outboard
Here's something to try. There are cans of plastic coat to dip stuff into to insulate them. Then you could also try to remove the terminals and use shrink tubes on the wires and then replace the terminals. If only for a short while you can see if that fixes the problem.
Jun 24, 2009 | Light Outboard Motor Boat Bass Fishing...
2001 grand prix v6 check engine light stays on
Have you tried disconnecting the battery for at least 30 minutes? This is sometimes the case and the computer just needs to reboot. If that doesn't work, your o2 sensor has probably gone bad. Its not an expensive fix. Leaving the check engine light on puts the computer into a setting called "limp mode". Limp mode is a safety to prevent damage to your vehicle. In this case the computer thinks there is something wrong and by going into limp mode tends to give you less gas mileage and less power performance as well.
Mar 31, 2009 | 1997 GMC Jimmy
Lost all memory on hard drive
Once it's gone, it's gone.
You can try loading the firmware update from Philips website, but this is unlikely to resolve.
Philips HDD – Reloading the Firmware Hack
1. Plug your GoGear HDD into the computer
2. From ‘My Computer’ right click the GoGear drive and format it. Be SURE you format it as FAT32 and quick compression is not on
3. Create 3 folders on the newly formatted disk called: ‘_System’ , ‘Data’ , ‘Media’
3. Download fom Philips the latest Device Manager for your kind of player
4. Install the Device Manager
5. On the Desktop, right click the Philips Device Manager shortcut, then Properties, then open file location.
6. Copy the folders you see there into the ‘Data’ folder
7. Copy the Firmware.ebn file into the ‘_System’ folder
8. Unplug the device and now it should run fine
-Tha Mp3 Doctor
Oct 16, 2008 | Philips GoGear HDD1830 MP3 Player
Boating Logo
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
