Question about Dell Inspiron 1525 Notebook
An error with blue screen that always come up stating "your computer will shut down to prevent it from damage" each time i start my computer
    Scholar:
  • 98 Answers
Oh my Microsoft blue screen of death, I would recommend reinstalling the Operating system. but this is an extreme solution, but will fix the error. Did you install a new hardware lately. This could be the root of the problem, make sure that your device driver is install for the hardware. also try searching Microsoft website with the error number and they will guide you form there, or you may reply to this post with the error message and I will help you further.
Posted on Sep 30, 2009
Why my computer is always encounter a blue screen ?? every time i use my comp it always a blue sreen.... im using windos XP V2002, what can i do to avoid this problem?? plzzz....help me....thanks... ...
CERTIFIED SHOP OWNER AND EXPERT HERE
Many times an operating system will refuse to shut down/ENCOUNTER A BLUE SCREEN because of computer Registry error problems. For example, if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 21, 2011 | iLO (2 GB) MP3 Player
The problem I'm experience with my computer start when a blue sceen appears. The statement states: A problem has been dected and windows has been shut down to prevent damage to my computer. If this...
If you are running Windows XP, the boot to the XP CD, press R when prompted to access the Recovery Console, then run the command CHKDSK /R at the C:\windows\system32\ prompt
If you get indications of recovering lost allocation units, then the disk surface of the HDD is likely bad and the HDD will need to be replaced.
If running Windows Vista or Windows 7, boot to the Windows DVD and select REPAIR MY COMPUTER
Dec 23, 2010 | Dell Computers & Internet
A blue screen appears when i turn on my computer.... sayin "a problem has been detected and windows has beed shut down to prevent damage to your computer."
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
If this answers your question, I would appreciate 4 thumbs
Sep 15, 2010 | Computers & Internet
Blue screen with lettering
what's the error code?
Critical errors are nothing to take lightly, and your computer may even shut down because of it. Your operating system is definitely in a vulnerable state. The good thing is that if your computer does shut down because of a blue screened errors, it usually does so as a way to prevent further damage.
suggest you scan your computer to fix the error here
http://www.keep-pc-clean.com/
Apr 25, 2010 | iLO LCT32HA36 Television
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
Blue screen in xp & system shuts down
Friend,
It is an indication that Windows is about to crash. You must do the following immediately:
1. Back up all your data if possible to a different drive. Or at least out of C:\Windows folder where MY Computer resides.
2. Go to www.ccleaner.com. And download CCleaner, the registry cleaner. What happens is that all programs registry themselves with Windows Registry. When yo uninstall the some do remove their traces from the registry, most do not. And the registry keeps bloating. This not only slows down the PC but also can cause a crash when a lot of junk is there. So use this CCleaner and remove all the junk from the registry. And you may not have to reinstall Windows. And if you have to then you have to and are prepared for it by having taken a backup of your data.
Dec 19, 2009 | Microsoft Windows XP Professional
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
A problem has been detected and windows has been shut down to pre
this error comes from hardware .restart the system and press F8 key in start then choose safemode option and log on the system.then remove the software which you install on the system before error.try it it solve this problem......rate it
Apr 16, 2009 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
