Question about Sony Cyber-shot DSC-W55 Digital Camera
"Access" appears when camera turns on
When I turn on my camera, I get the word "access" on the screen. I've checked to make sure the battery is full but that doesn't seem to matter. I turn it on and off and that doesn't help either. Any ideas?
  • dcolner Oct 04, 2009
    I don't see a solution on this page. what am I missing? This isn't at all helpufl.
5 Suggested Answers
SOURCE: DSC-W50 sony cybershot
I had the same problem with my DSC-W55. I actually just called the customer service number on the sony website and they told me how to solve the problem.
- Take your battery out
- Press and hold the power button for 60 seconds
- Re enter your battery
- Voila.. it should work when you turn it on. Mine did.
Posted on Jan 20, 2008
SOURCE: Access appearing on screen
Hello!
Same mechanism problem here on a DSC-W50. For me, it did not work out to PULL the lens, but to push them. I just opened the camera and it tried to calibrate the lens with no success for about 4 times, after it just let them out and displayed the "power off and on your camera" message. The problem is that on this model of camera when the lens is out you cannot push or pull it. So I thought of a trick: when the lens is moving, you can pull or push them. Anyway, this is what I did: with the lens out, i placed the camera with the lens towards a soft surface (bed) and gently pushed on the side with the display. First times it didn't work, so I had to push harder and finally it worked and now my lens is aligned and the camera is working as if it were new. I suggest you try to push or pull the lens while it is moving GENTLY at first, and if it does not work, try harder - really hard! It will do a click at some time and work fine!
Posted on May 10, 2008
SOURCE: 'access' Problem
my camera is turned on access end bloqi
Posted on Nov 10, 2008
caroldon
  • 17130 Answers
SOURCE: when i turn on the camera the lens moves in and
This fault seems related to the processor controller unit as it fails to reset when the power is switched. Also the lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Posted on Jul 13, 2011
Camera not working
The word ACCESS appears in the LCD and the digital camera does not respond. Solution
sp.gif sp.gif If the camera appears to freeze or lock and the word ACCESS is displayed in the LCD, then a problem has occurred during the reading or writing of data on the Memory Stick® media. This could be caused by the media, or the camera itself.
Follow the steps below to troubleshoot this issue.
  1. Perform a power reset on the camera.
  2. If the issue is not resolved, turn off the camera.
  3. Remove the Memory Stick® media from the camera.
  4. Clean the metal contacts on the Memory Stick media with a soft, dry cloth or clean pencil eraser.
  5. Reinsert the Memory Stick media into the camera.
  6. Turn on the camera.
  7. If the issue reoccurs, turn off the camera.
  8. Remove the Memory Stick media from the camera.
  9. Insert a different Memory Stick media.
  10. Turn on the camera. NOTE: If the issue does not occur with different Memory Stick media, the previous Memory Stick media may be faulty and should be discarded.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C267279
Jul 23, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When i on the camera "Access" appears on the screen,the lens comes out and goes back 3 or 4 times and after few moments it appears "turn the power off and on again".When it is shut off and turned on it do...
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 06, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
Wont turn on anymore. shutter goes in and out and screen wont turn on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 04, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Screen white
APPEARS TO BE A COMMON PROBLEM WITH THIS CAMERA.
The internal contact to the LCD screen is loose. Grab the camera using both hands with thumb and index fingers on bottom corners. (usually the left bottom corner) Squeeze hard! Voila! You will be doing this occaisonally as it drops out.
Sep 26, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Remove the memory card and the battery
Contact KODAK:
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
'access' Problem
Hi, I just fixed my daughters camera w/same problem.....I read on another site that you squarely hit it on table while holding in hand....I didn't have to slam it just one slightly firm hit and it works fine now...been broken for weeks and tried resetting and pulling battery to no avail...the hit works! viewing screen side is the side I hit on table, only had to do once, and not that hard.(camera was less than 2yr old dsc-70) good luck!
Oct 21, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC-W30 ACCESS problem
try hitting it against something harder (like a table). I just did and it worked for me.
Jan 28, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Access and turn on again the camera
I called Sony at 800-222-7669 and was told to turn camera off, remove battery, turn camera on holding the power button for one full minute, put battery back in and power up as usual. Probably the one minute drains the residual energy in a capacitor.
I passed the info to my wife but she had solved the problem by tapping on the front to release a bind on the lens coming out. Probably caused by handling during her trip to California. So I don't know if the one-minute thing works but it is certainly worth a try.
Hope this helps you!
Dec 29, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
