Question about Toshiba Satellite A20 Satellite A25 Series Touch Pad - P000378380 CD-ROM Drive
Synaptics touchpad not working
Hi i have had my toshiba equiim laptop for 11 months now and it was working fine. It has now stopped working, moving or anything. It stays in the middle of the screen and does not movee even on the startup user page.
  • Anonymous Dec 04, 2008
    my mouse work fine while windows is loading, but the touch pad and mouse keys stop working when windows is fully loaded. what can I do?
  • facettech May 13, 2009
    The same problem...it just stopped working
    Problem Solver:
  • 19 Answers
In a TOSHIBA LAPTOP - When the Synaptics Touchpad stops working in Windows Vista. You should download the 'Toshiba Value Added Package' and then launch 'Flash Cards' utility. There is a setting to enable the Function Keys, and thus enable the Touchpad! Voila.
Posted on Nov 16, 2008
  • 205 Answers
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Posted on Dec 19, 2007
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Toshiba Satellite A215-S4747 DVD/CD crash?
Normally when this happens, what one should look out for is the possibility of it happening again. Like desktops peripherals such as disc drives would have connections internally. If you can have them checked out if there were loose connections. It could also be faulty internals that will break down soon such as ICs in the drive.
Sep 11, 2009 | Toshiba Satellite A215-S4747 Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Toshiba satelitte L40
could be a short in the motherboard. would need to be looked at by a tech to see if anything is blown.
Aug 11, 2008 | Toshiba Satellite A135-S2276 Notebook
that can happen..there's a connector under the keyboard, that may have come loose or disconnected
Mar 02, 2008 | Toshiba Satellite M35X-S349 Notebook
Battery failure
Yes perhaps you can be sure if you BIOS up to date. latest version of BIOS is v1.20. This version has several important fixes including critical battery wake up. You can obtain the BIOS from Toshiba support website. I am adding the direct link for your convenience.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1721794xml&sliceId=&dialogID=30999201&stateId=0%200%2030995558
BIOS update is a critical process that you should close other applications and make sure computer is on AC power. the update process takes few minutes.
If the Issue persists after BIOS update you can think about replacing the battery, Just to remind you that usually brand new laptops warranty covers the battery for a year. So you have said that its only 11 months, you can think about using warranty.
For Toshiba Tech Support
1-800-457-7777
Good Luck
Jan 10, 2008 | Toshiba Satellite A135-S4467 Notebook
Computers & Internet Logo
641 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
