Question about Car Audio & Video
My mrv f345 amp reads CUR on display screen and has no sound.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
That error appears usually when the speakers (especially subs) aren't getting the current they need from the system. Check your wiring and make sure you're using the appropriate gauge wire. Too small of a gauge in wire can cause this.
Posted on Sep 30, 2009
Alpine mrv-f345 cuts off when...
Yes sounds like your not getting enuff power from the battery could be your alternator you should have it tested. Also have you try'd a capacitor? I put one in my car and it stopped cutting out...
Feb 05, 2010 | Alpine MRV-F345 Car Audio Amplifier
My amp turns on but the sound goes in an out
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Alpine MRV-F345 Car Audio Amplifier
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
Fan not working
iT SOUNDS LIKE THE FAN IS NOT WORKING RIGHT, SO CHECK OTHERWISE IT WILL COOK YOUR AMP
May 16, 2009 | Alpine MRV-F345 Car Audio Amplifier
Mrv F345 power cut out and now the screen flashes blue
disconnect all of the speaker wires at the amp and turn your system on -if the amp stays on then you likely have a roasted coil in one of your speakers somewhere and causing a short which is shutting your amp down into protection mode-if the amp wont stay on with nothing connected to it then you have probably roasted something inside the amp and uhhh good luck bro
May 09, 2009 | Alpine MRV-F345 Car Audio Amplifier
Alpine MRV-F345 VLT ERROR
This is an indication of a voltage error, I have seen this when the voltage regulator or the car battery is begining to have a problem supplying enough current to the amplifier. Check the voltage levels with the amp turned off and then turn on the amplifier, if the voltage drops this means that there is poor voltage regulation and this may mean that you will have to replace the car's voltage regulator.
I hope this helps,
Thank you,
Shuttle83
Apr 20, 2008 | Car Audio & Video
Displays "CUR"
You probably have too low of an impedance load on ot (too many speakers or wrong kind). It has to have a minimum of 2 ohms on each channel, or 4 ohms if bridged (that means don't put 2 subs on the bridge!!).
Sep 22, 2007 | Alpine MRV-F345 Car Audio Amplifier
Over heating
you trouble shoot the problem by opening unit and force-powering fans to test for overheating during "being used loud for a few minutes". Read the fans' label for proper voltage to apply and proper polarity. I am guessing the fans will run on car battery voltage of 12 volts. Also, attempt to close up the unit to simulate real conditions. There should not be fuses for the fans. If unit is now cooling, then look for faulty thermistor, which turns the fan on during rising temperature. Once thermistor is located, a fast test is to "jumper" its two wires to simulate turn on.
Jun 16, 2007 | Alpine MRV-F345 Car Audio Amplifier
Alpine Amplifier Cuts in and out on Passenger side while driving
this isnt a complex problem but both units may need service
Mar 12, 2007 | Alpine MRV-F345 Car Audio Amplifier
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
