Question about LG BG8000ER Air Conditioner
LG LWHD 1200 HR Air/Heater fan will not start.
Plugged in my LG Air conditioner/heater for the first time yesterday and the fan won't cut on. I tried to run heater, air, and just the fan and it seems only the fan won't cut on. Did I miss something?
  • Anonymous Mar 18, 2014
    electric heater on 15 gl packaged terminal air conditioners are going out what is the problem
  • 80 Answers
May be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Posted on Dec 19, 2007
Why won't the fan come on when I turn on the heater? It was working last week.
You are smart to leave it off right now. It sounds like the fan motor bushings are dry or gummed up. Take the outer case off so you can see the fan motor. There may be a spot at each end of the motor to add several drops of oil each or if you can get to the shaft near the bushing of the fan motor you may try putting some oil on the shaft and rotate the fan to work it in to the bushing. It is most likely time to replace the fan motor.
Feb 25, 2015 | Electric Arctic King WWJ1-12ERN1-MI8...
What causes my heater to quit heating
some are designed to operate a short time after heater cutting out to pick up residule heat
Jan 06, 2014 | Goodman Heating & Cooling
LG ac with heat model lwhd 1200 hry7 has power to it, cord reset, but nothing comes on, compressor or fan
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Oct 12, 2011 | LG Heat cool Window Air Conditioner
We have an LG model #LWHD-1200HRY. The air is
is it a heater also if so electric/or heatpump.
Jan 15, 2010 | LG Heat cool Window Air Conditioner
My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Jan 07, 2010 | LG Heat cool Window Air Conditioner
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
LG split system heater cooler. the heater is not working and fan outside is working
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Feb 20, 2009 | EdgeStar Portable Air Conditioner Heater
My heater won;t work
check induction fan motor first...then check the rubber tube and the switch it ataches too. this switch should close if the induction motor is running...but also...it HAS to be open before start up.
Dec 08, 2008 | Carrier 38CKC036 Air Conditioner
LG BG8000ER Air Conditioner Logo
442 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
