Question about Brother MFC-8220 Fax
Receiving Faxes I am able to send fax without any problems but I cannot receive any the person on the other end said he an 0018 busy/no signal can you help me with this?
  • Anonymous Jan 07, 2008
    CANNOT SEND OR RECEIVE FAXES.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Here is the manual try the troubleshooting sectiomn
http://www.retrevo.com/s/brother+8220++fax++manual
good luck
Posted on Dec 26, 2007
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
My laserjet printer keep showing memory is low, cannot fax, how do I correct problem?
This model of fax is meant only for lite to moderate use when sending and recieving faxes. If you are using this fax machine in a busy office environment which is constantly receiving faxes all day or sending out faxes it does not have the memory to support this type of use. You need to go to a higher end model. Have a sales person assess your usage and they can recommend a model that would be suitable to meet your needs. HP also posts under each model description what the monthly maximum capacity each model can handle on the website.
May 28, 2010 | HP LaserJet 3050 All-In-One Printer
Problem receiving faxes with hp officejet 7110
Most likely it is a phone line problem, not ypur machine. Fax modems work or they don't work.
make sure your phone line is not digital.
Mar 16, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Fax
HI,
u need to make change to answer ring pattern from the front panel of unit .
Set the fax function to answer the phone automatically by pressing the auto answer mode button on front panel .
Thanks
Jun 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother MFC-8220 Fax Logo
203 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
