Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
How do we auto program the tv without a remote?
Auto program a Magnavox TV without a remote
As there is no 'Menu' button at the front panel of the TV, you can't do a re-tune, without a remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 15, 2013 | Televison & Video
Programming a TV without remote
You must have its remote control to program this TV.
Feb 17, 2013 | Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
Can you auto program a old phillips flat tv without a remote control?
Only if you have a menu button on the TV. But you can buy an generic remote and program it and then you can have a romote you can use. Good luck,
Shawn
Jan 30, 2011 | Televison & Video
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a Sony Trinitron model KV27S35, but no remote. How do I program the tv without the remote?
The SETUP button on the case accesses the menu.
Press Channel +   to select Language.
Press Volume -    - now the tv will be reset to factory condition.
Press Channel + to start the AUTO PROGRAM and wait for it to finish.
Press Channel -  to exit it.
That is all. If you need more then all the menu options can be accessed thru the key on the tv.
Aug 17, 2010 | Zenith ZN110 Remote Control
Trying to hook up the tv to direct tv, don't have remote and cannot get tv on to channel 3
The only work around you have without a remote is sloppy. If you are patient, give it a go: connect the box to the TV (cable/ant input), turn on the direct TV box, using the TV button panel (here comes the sloppy) fumble your way to the auto-program menu, start auto program. When the auto-program is done, you will have just CH 3 memorized, so the CH -/+ button will only go to that channel. Worst part will be figuring out the buttons on the TV... it can be frustrating. It may take a few tries, that's why I call it sloppy. I hope this was useful, best wishes.
Apr 19, 2010 | Insignia NS-24 TV TV
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Cannot set up TV.We bought floor model without remote or manual.We need to auto program channels without remote
get the original remote for the set. You won't be able to do the menu functions without it.
C-Dog
Feb 10, 2008 | Televison & Video
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
387 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
