Question about Intel D845GVSR Motherboard
No display, no cpu fan running, no any beep but led on mother board is on.I replace power supply but no result
    Guru:
  • 597 Answers
Do the following to check motherboard.
1. Take out all cards from motherboard except video card. Unplug ribbons to CD-Roms, hard drives and floppy drives.
2. The only thing plugged into your motherboard should be video, keyboard and ram.
3. Check once again that all the power connectors from the power supply are properly plugged in. There may be two or three of them depending on the type of motherboard. Try turning on system. If you get no response then try next option.
4. Find the wire coming from your power on button and trace it to the motherboard. Pull the wire off and use a screwdrive to short between the two posts. If the power button is bad this should start the computer. If not your motherboard is probably toast.
Posted on Sep 30, 2009
NO beep no display.
Hello try to renew the power supply, with one you know is working.
I think the power supply is not giving enough power, or have burned a power rail.
Here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=d101ggc
But the mainboard could also be failing itself.
Look also here:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 23, 2013 | Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Problem of motherboard
Could be a power supply fault, motherboard fault, or fan fault. Many new motherboards will not power up if the fan doesn't rotate, to prevent the processor getting fried.
Dec 06, 2007 | Intel D101GGC Motherboard
Intel D845GVSR Motherboard Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
