Question about Indesit W 123 Front Load Washer
Indesit washing machine w 123 front load
The concrete weight block attached to front of drum has broken loose and i want to know if this can be re-fixed.
How do I get the front off the machine, or does the machine need to be lifted up from the casing, or dropped down?
Can I get a new block, or should I just scrap it?
Michael Martin
  • Anonymous Jun 17, 2008
    Tried screwing concrete block as it has come unfixed but it keeps coming off, we only manage to get one wash done at a time.....any ideas on how to fix for good or is it time for a new washing machine????
    President:
  • 1,294 Answers
You have to get to it somehow. Get two metal strips & just join the blocks by drilling and screwing.
Posted on Dec 30, 2007
The machine goes through cycle but drum not turning switched cycle and it worked for two washed then drum stopped again
I advise you to remove the motor, and check the brushes in the motor, and check for loose or broken wires at trhe same time.
If brushes o/k, then it is probably going to be something more serious.
This being the case, then it could faulty programmer or similar.
Hope this helps.
Thankyou.
Nov 26, 2009 | Indesit W 123 Front Load Washer
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
Dancing washing machine
Check that the washer is level , and that there is no movement on it.
Make sure you have not overloaded it.
An out of balance load could cause problem , especially if you had something heavy or extra large in it..
A loose concrete balance weight., or suspension spring unhooked or broken..
Not draining properly ,check filter if there is one usually at front behind removable cover at bottom.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Indesit WA 125 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Dec 02, 2008 | Creda IWD12 Front Load Washer / Dryer
Banging washing machine on spins
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Nov 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Knocking noise on spinning
it may cause more damage to other damper/suspension components if used. confirm exact fault- also check concrete weights for security.
Feb 16, 2008 | Indesit W 123 Front Load Washer
Indesit WA105 - drum is loose and fails to spin
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Jul 23, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
205 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
