Question about Mr. Heater MH175KT Open Flame Utility
Have a Mr. Heater 175000 BTU that is leaking at the bottom were the drain plug is located. The O-ring is cracked, I need a replacement for the O-ring. What size do I get?
  • 3,740 Answers
Tip the heater up so that the fuel is away from the drain plug hole and take the plug to an auto parts store. They have bulk o-rings there and can fit the needed O'ring to your plug.
I checked the parts manual:
http://www.mrheater.com/upload/newsletter/mh_50_75_125_150_175_210_BL.pdf
There is no drain plug listed for the tank. Only the tank assy. (Item 2)
You might even be able to get a copper crush washer similar to what is used on an automobile or motorcycle oil drain plug.
Kelly
Posted on Feb 28, 2010
How does this unit drain? I have noticed water pooling in the fan area and one small drop at a time coming from the bottom. I have a norpole window air conditioner 12,550 btu nprac10kewgz
-It could be loose drain plug, small crack in radiator some where.
-Test to find the leak location and fix or replace it.
Good luck
Mai
Jun 23, 2017 | Refrigerators
I have a leak from the bottom of the pump
Also, check for the actual mechanical shaft seal, they leak, and appears as if it's coming off of the wet end. Making it look like the drain plug could be leaking, or the area between the volute which is the pump housing, and the cover, this would normally be a failed gasket or O-ring, depending on the brand. Sometimes just tightening the cover to the pump housing correct this issue.
Jun 08, 2015 | Pool & Spa
I have 2 heaters that will run out of fuel when tank is still half full
What size LP tank are you using? If you are running (2) 175,000 btu heaters on a tank that is too small, especially in this cold weather, it will not have enough vaporization to keep up with demand. This will cause the outside of the tank to frost up and the pressure inside will be too low to run the heaters. You need more wet surface area, i.e. a bigger tank or just manifold 2 tanks together.
Feb 28, 2015 | Mr. Heater Heating & Cooling
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Water leaks from a small opening on the bottom left of radiator. What is the opening for?
if you mean the driver's side, that opening is where the radiator drain plug is located. The drain plug has a O ring that may have gone bad and will need to be replaced. Auto Zone or Napa will have the replacement part needed to stop the leak, and do not add any radiator stop leak. The stop leak will cause a restriction to your heater core and in the winter you may have heating issues.
Thank you for using fixya and good luck with the simple fix.
May 11, 2010 | 1996 Oldsmobile Eighty Eight
Heater leaking at manifold
1. Check o-rings at connections and replace if required. 2. Check header for cracks. 3. Remove heat exchanger and check for leaks. Replace parts as required.
Apr 19, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
HI. i have all rpo 175000 btu kerosene heater.. wont pump the kerosene. I cleaned the pump on the back of the motor and I noticed scratches on the aluminum plate. any Idea what should I do.
check for dirty filter, air leak at pick up tube connection, also hold your finger over the pressure relief momentarily to see if it is leaking off pressure. also could be a stuck vane in pump.
Jan 13, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Pilot will not stay on
replace your regulater,which almost cost as much a a new heater.I have own 4 or 5 and finally got a good one,I have in the past cleaned out the regulator that was plugged with oil from the propane,they put oil in the propane for leak detection,I hope this helps you
Dec 02, 2009 | Mr. Heater (F274825)
Mr. Heater MH175KT Open Flame Utility Logo
155 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
