Question about Kenmore Washing Machines
Kenmore washer keep trip the breaker - Kenmore Washing Machines
  • 183 Answers
SOURCE: Washer Tripping 20 Amp Breaker
probably a faulty heater.
Posted on Dec 27, 2007
SOURCE: My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Posted on Jun 30, 2009
a00gha
  • 21 Answers
SOURCE: dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Posted on Jul 14, 2009
  • 401 Answers
SOURCE: Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Posted on Jan 11, 2010
mkh5094
  • 145 Answers
SOURCE: Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Posted on May 02, 2010
Microwave tripping breaker
The microwave may be too big for the circuit it's on. The breaker is tripping to protect the circuit. Try to determine how many appliances/lights/etc are running on this circuit. If there are alot of things, you may try turning some of them off when trying the microwave. If not, then you may have an electrical issue in the wiring or the breaker.
NEVER replace a breaker/fuse with anything larger than what's already in there (recommended by code or a manufacturer).
Feb 15, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Why does it keep on throwing the breaker?
Hi, the reason this unit, any unit, is tripping breaker, blowing fuses, is that you have a short circuit, somewhere in the unit, between the Phase Wire and Neutral/Earth.
Usually this is on the main PCB, but in reality, it maybe anywhere within the unit.
With a problem such as this it is nearly impossible to tell exactly where the problem lies, without performing the troubleshooting steps, accordingly i have given you a link below to download your Service and repair manual, also i have included a DIY help site as well.
http://www.acmehowto.com/howto/appliance/washer/washer.php
Above the DIY help site, below service manual.
http://appliancejunk.com/forums/index.php?topic=2946.0
Oct 03, 2010 | Kenmore HE2 Plus Front Load Washer
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Our kenmore 697267 keeps tripping it's circuit every 5 minutes or so... what's the problem with it? Is it dangerous to just keep resetting it?
definatly a prob if tripping breaker every5 miin, resetting breaker is not good for either the breaker nor hte dryer, that would be hard to determine why without actually looking at though, i would probably calll someone to have a look at that one
May 02, 2008 | Kenmore 73952 Gas Dryer
Washing Machines Logo
103 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
