Question about Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM)
My adsl light is off and iam not able to work on internet please help me.
No signal getting to modem contact ISP right away
Posted on Sep 30, 2009
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
Internet light on router diplayed red
The ADSL installation details have changed, so you need to update the router.
Check the router has not been moved too far from the laptop.
Jan 27, 2014 | NetGear DG834G Router
Iam running internet cafe i have a adsl internet connection, I have bought one WAG54G wireless adsl router and 8 port Netgear switch, i have establish 7 connection through the switch connected with router...
The internet is disconnecting that means the problem is with the router. you also said that the router is getting hot.
I think probably you can try to upgrade the firmware of the router.
Or if it is a new router then try to get it replaced from the store.
Click Here for more info about the networking
Oct 07, 2009 | Linksys WAG54G-UK Router
How to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Iam having an issue with the dlink router , getting 0.0.0.0 ip address for wan
Hi, first establish that the wires are plugged in to the correct ports, WAN port on the back of the router is in the internet port on the ADSL (assuming that is what your using).reboot the ADSL modem and wait for the light to settle, the link light should be solid. The ethernet light does not need to be solid, and the Act or activity light should be blinking, Now go to the command prompt and type in
> ipconfig /all. you should get a WAN ip. Otherwise, check if your service provider needs the MAC address of the router to establish it on the network...Telus used to need this. If this does not work, take the wire from your computer and plug it in directly to the back of the modem, this should get an WAN IP so you know that the router may need a bit of tweeking and a reboot of the hardware may be in order to sync everthing up again,,goodluck
Jan 06, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Thanks for replying to my problem
1.Ok check that you've light for ADSL or not?
If you do have light for ADSL that mean your ADSL is working fine.
2.If ADSL light is ok bu internet light is not working that mean some wrong setup in the router
what can it be ???
only 2 possible case
1.your username,password and all require setup is not correct
2.you have to setup Domain Name Server.This is a 4 group of number like 202.183.255.21(just sample).You should ask the provider that you need to put in your router or not?? If the answer is Yes then you should ask them for this number. If the answer is NO then you've to set in your Router that you use AUTO DNS
After doing this setup..again monitor that your internet signal is up...IF yes...then its running..
Goodluck...takecare.
Apr 20, 2008 | HP Pavilion dv6000z Notebook
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM) Logo
235 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
