Have a Coleman Evcon AH16W10BA dripping water from EVERYWHERE!
The whole underneath of this unit is dripping water. I have also had the coils cleaned by Sears. Currently the drippings are filling an 8 gallon bucket in a day or less. This is in a two story house in Florida.
I have rigged tin foil all underneath the unit leading to the big 8 gallon bucket which I frequently scoop the water out of. What can I do?
  • 358 Answers
Probably the drain is clogh (it's a p.v.c. pipe , or could be a 3/4 or 1" hose comming out of the inside unit) , to clear the drain , the best thing is to blow air pressure thruogh it , and keep it clean by pouring about a cup of bleach every 3/4 months.
Posted on Sep 30, 2009
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
Coleman Evcon BGU12520A won't ignite
check the ignitors condition is it cracked broken burnt out etc , ifn so then it will need replacing , or check the pressure switch is working try jumping it out and see if the ignition glows ,
Apr 09, 2010 | Heating & Cooling
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
I have a coleman evcon mh unit and it is dripping water on the floor the pan appears to be rusted, any cheap fix
if you can clean pan shine flash light through bottom try to see hole then use two part epoxy like jb weld to seal
Jan 04, 2009 | Kenmore 72187 Air Conditioner
My Coleman Evcon AC unit ices up everytime I turn the unit on
If the AC unit doesn't have sufficient air flow to carry away the cold air then condensation and the extra cold air will freeze at the unit. good air flow is the solution. Change the filters, clean the unit by removing the covers and looking for pet hair/leaves/dirt inside the coils of the unit. and make sure the ducting is connected and not clogged.
Jun 05, 2008 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
